- Nov 11, 2006
@jant71 sorry, i meant the adv model x.
Some reviewer on YouTube commented they feel cheap and not worth 100$. They didn't say specifically why the sound while good was up to the price.
I'm also not keen on triple tapping just to switch tracks, why not switch it around with volume which is double-tap?
I have great results with SoundCore Life P2 for calls. Excellent mics. Not the best for music, but I almost exclusively use them for calls (phone, VOIP, Zoom).Yeah I've made several posts about this. TWS mics are all around awful when compared to anything else IMO. I'd suggest a dongle mic options (like Jaybird) or a wired mic for meetings.
Hi, helmutcheese,Thanks, give me a few more days of testing as now they have been fully charged overnight as I assume out the box they may not be though said 100% they did not last very long.
Do these support pairing with multiple, devices (I do not mean multi-point connection) and remembering each of them or are they simply re-paring each time I swap from phone to PC?
How do I power them on or off outside the case?
Also BT 5.0 does not necessarily give you more distance, it is still set to a minimum requirement of 10m, it will depends on the size of devices antennas and what tweaks can be done to help them and the voltage to the chip so Bluetooth class 2 or higher Bluetooth Class 1 which can be 15-20m or even higher on larger devices up to 50m easily.
I am not trying to walk far away from devices even in my testing so far but they break up simply moving about a small amount even sometimes quite near the devices, they give no stuttering warning and no voice prompt just disconnected and no voice prompt when they reconnect as you get closer.
Apollo Bold is equipped with customized antenna. It is 5V, 450mAh. Hopeit helps you to understand.yes, thats an antenna or power problem. Did have some of those tws from ali that I got refunded. Just throw them in the trash since its most likely a hw problem.
Then on Android you would need tap it 30x to go from 0-100% volume (10 steps by default).
On my Pixel there are 25 volume steps.
Yep. The manual here: https://www.tranya.com/tmp/file/2ad25f70d9.pdf confirms that weird control setup...so sad. I was going to wait until this released on Amazon for cheap, like every other Tranya product, but the wacky controls makes this a no-go for me. Might reconsider the Rimor...Some reviewer on YouTube commented they feel cheap and not worth 100$. They didn't say specifically why the sound while good was up to the price.
You can get the T10s for $40 on Tranya's site with the code JULY50. Trust me, you really don't want the Rimors. They are awful.Yep. The manual here: https://www.tranya.com/tmp/file/2ad25f70d9.pdf confirms that weird control setup...so sad. I was going to wait until this released on Amazon for cheap, like every other Tranya product, but the wacky controls makes this a no-go for me. Might reconsider the Rimor...
What TWS ya got so far? What is your fav sound sig?Yep. The manual here: https://www.tranya.com/tmp/file/2ad25f70d9.pdf confirms that weird control setup...so sad. I was going to wait until this released on Amazon for cheap, like every other Tranya product, but the wacky controls makes this a no-go for me. Might reconsider the Rimor...
No, most cheap/aliexpress iem mics are actually terrible and will feedback all sounds pushed to earphones back through the mic, I've tested many cables and iems and have only found a few. You have to find some that are made with a good mic. I believe Xiaomi uses knowles mics, Huawei might as well. The apple one is good as well. TWSs don't have to share cables in that manner and have an entirely separate mic circuit and so can do better, but most cheap TWSs have crap mics so... The best mic I had so far was on the earfun air.Is it safe to say that the microphone on any decent wired earbud is better than the microphone on any TWS earbud?
I am thinking of getting a pair of KZ ZSM with Mic for work to attend Zoom meetings. I just want to make sure people will be able to hear me.
No? Shame. Is it because of their SQ? Cause their feature set seems perfect to me.You can get the T10s for $40 on Tranya's site with the code JULY50. Trust me, you really don't want the Rimors. They are awful.
