voicemaster
Lets enjoy our TWS!!
You should check out the Fiil T1x. They are a better bowmaker.I should try audiobooks.
Yes we all have different ears don’t we. I also enjoy the all around performance of my T5, Bomaker, SSK and APP. The hissing from the L2P made that an impossible option.
Mpow M5... comes with smooother bass. deep, less impact.If I'm looking for a TWS with the SQ and signature of the SSK and effective transparency mode, which ones should I be looking at?
New version has M5 written on boxDoes anyone know if the older version of the Mpow T5 also supports Android 9.0? The one I'm currently looking at doesn't say if it's the newer upgraded M5 version so I'm not 100% sure if it will work.
Bartig = scarbir. Com I bought 3 tws based on your recommendation. Best reviewer I ever followed!!I plan to, but it isn’t the highest on my priority list with so many new TWS arrivals.
Mpow M5... comes with smooother bass. Less deep, less impact.
OH sorry I missed the transparency part..Pretty sure there's no transparency mode on M5
Preach!Well have to admit I started to struggle with acoustic and piano settings on the L2P so switched to flat and have reinstalled the Neutron Player so I can control my EQ. I listen to almost all my own library no streaming so it's fine for me.
Hey Soundcore, if your reading we would all love a custom EQ...
Day 2 with SSK bt03... It has won me over I can't decide if Mpow m5 is better. I'll have to keep both for now..Hi all, I received my SSK BT03 last night, here are my findings compared to what I already have:
1) Bose 700: Great bass, detailed high. slight V shaped. Was my best sounding headphone for a while. I knew what sound I was looking for - so still searching.
2) Umidig Upods: No bass, not even average, Does not seal well. Have to turn off blue tooth so the buds can pair. Giving away soon,
3) Letscom ST-BE30: Thin mids, shouty highs, no bass. But good seal.
4) MPOW M5:
The mids are a tad less recessed than Bose 700. Cheap as it may be, the m5 has replaced the Bose 700 as my favourite sound. Although there are reports that the M5 highs are rolled off - the sound signature is exactly what I'm looking for (they sound thick which I like) - the metal string Acoustic guitars do not thin out like they do with most earphones that I've tried. Snare drums and rim shots sounded full bodied and not come off like toys (some KZ earphones my audiophile friends raved about fall into this category--like toys). The bass is excellent,.. smooth like how a bass guitarist would touch the strings. BTW when a guitarist touch the string it should sound like touching and not plucking nor slapping - if you know what i mean.
5) SSK-BT03:
Enter the SSK BT03.... it's Fabulous...
The M5 mids sounded thicker. The SSK sounded clearer.
The SSK bass seems to be louder, have more impact, tightness or slam.
At first listen - I thought Mpow M5 has met it's match... I'd describe the SSK as the M5 on bass steroids. And would pick the SSK as my new #1
But after a few rounds of listening, I finally figured it out - the SSK sounds great for electronic music and movies - with that impactful bass.
When I played instrumental band music on ssk- it sounded like the bass guitarist has gone rogue - turning up his bass vol by 10% and heavily plucking the strings.
Thus music with running bass on M5 sounds smooth while there is some attack / staccato effect on SSK BT03.
For reasons above my personal preference goes to MPOW M5 due to the type of instrumental music I listen to.
If you prefer deeper, more impactful / tight bass - SSK BT03 is better than M5. If you don't mind that rogue bass guitarist doing his heavy stuff in there.
Hope it helps.. I'm still trying to stay low budget
What did you buy that made you unhappy?I bought three and very unhappy. I either hear things very different from him or he is really off mark in his reviews based on my experience...
I'd like to hear your impressions of the Rimor without the Samsung Adapt Sound profile on. I tried for days to like them via Iphone no eq'ing. The bulbs didn't fit great in my ears and no matter what tips I used, I didn't feel like I was getting a great fit like the B503's. Also, If you have an SSK or Anbes 359, do an A/B test an prepare to be shocked. I will say that the drivers in the Rimor are def. the same if not better quality than the B503's they have really excellent textured bass,but there's just not much of it. I also found them really responsive and the soundstage is great.
