Going fully Wireless IEMs. Too soon? Or are we there yet?
post-15328839
Post #16,156 of 26,811
gibletzor
USA
USA
Looking at wireless ear buds as my Bose sound sports are dying by inches. I have plenty of great IEMs and cans for detailed listening. I mainly am looking for a pair for phone calls while at the grocery or similar and music at the gym.
I run/cycle and lift. So solid fit, sweat resistance are primary necessities. Microphone and then music reproduction quality.
I've read through here a bit and on other online searches and it seems that the Mpow and QCY TS1 are reviewed favorably. There also is the JLab Audio JBuds from Best Buy for Black Friday.
My question is: Out of the three they range from $15 (QCY), $30 (JLab), or $40 (MPow). Is there an appreciable difference in the sound/microphone quality of these to justify spending more than the $15?
Or is there really a huge enough difference for the higher cost, mainstream brands like B&O, Jabras or Senns? Especially for this use case.
If you want something with great sound quality and great phone call quality get the Tranya B530. They're $60 but have a $15 off coupon on Amazon right now. For $45 it would be hard to do better!
post-15328862
Post #16,157 of 26,811
magi44ken
With AirPods Pro, I realized Qualcomm Tue Stereo Plus isn't necessary. I'm pretty sure Apple doesn't use that chip, yet left and right earpieces connect independently on my Android. APP does everything well and don't look like a bluetooth headset from the early 2000s.
Nice to know that it also works with Android phone.
However I assume APP still uses master and slave for stereo mode where Qualcomm Tue Stereo Plus connect directly to the phone for both left and right buds. This resulted in lower latency and battery life to the master bud.
post-15328876
Post #16,158 of 26,811
duo8
Airpods since the first one have already used direct L/R connections.
post-15328932
Post #16,159 of 26,811
magi44ken
I did not know that. Does it also works on Android phone with direct L/R connection?
Right now I'm looking for a good microphone and direct L/R connection as my next TWS.
post-15329013
Post #16,160 of 26,811
wksoh
Meanwhile in Canada... 350 new! I remember when I got my 1000X for 330 on Black Friday around the time the 1000XM2 came out...
I've been considering budget options like the Dyplay Urban Traveller 2, EKSA E5 (no AptX but has ANC) and Meizu HD60 (no ANC but has AptX).
Any brands carrying the UFO TWS with AptX? (aside from purchasing directly from Alibaba OEM)
Not all UFOs are the same... they only look the same.
I have a Letscom BE30 that sounds shouty with thin sounding mids and not much bass.
Enter the SSK BT03 - sounds many levels better. The only one advertised as 10mm driver. it has rich sounding mid and high is detailed I think near my limit ( any higher I will think acoustic guitars will start to pierce). Has low subsonic bass that interferes little with mid.
I'm not sure about Kissral18 - it doesn't advertize as 10mm driver.
post-15329026
Post #16,161 of 26,811
cwill
I have a Letscom BE30 that sound shouty with thin sounding mids and not much bass.
This is absolutely correct. I bought the R18 based on all the UFO hype. While they sound fantastically detailed and clear, they are severely lacking in the low end. Then came the SSK's...what a difference.
Reactions: Grayson73 and wksoh
post-15329057
Post #16,162 of 26,811
hifi80sman
CA, USA
CA, USA
I hate myself. But I’ve got to know how they sound
Thing is, they look absolutely beautiful. Story time. I went to Hawaii for vacation and took them with me to use poolside. I'd listen and relax for 1.5 to 2 hours, jump in the pool, jump out of the pool, apply sunscreen, resume listening. Walk around with those things in, fill up my soda cup, walk back to lounger, proceed to lounge. Repeat.
post-15329087
Post #16,163 of 26,811
Nuke142
post-15329094
Post #16,164 of 26,811
wksoh
Little update on my impressions of the FiiL T1x. I don't know why I left out the SSK/Anbes 359 in my comparison. I listened to a couple tracks with the T1X and then the SSK's. I felt like Moses coming out of the desert of thin mids and rolled off bass. If you own the SSK, it's just absolutely Stomps the T1X. It sound is so full. I use the JVC spiral dots with them and it really brings out the highs and high mids. The soundstage is def. much wider and the bass is perfect. But again. If you like the colder sound of the Tevi, Bowmaker etc. You will really like the T1X. In my opinion it's a better version of both. it's high detail are really impressive and it has better bass then both. It's been a month or so since i've heard either, so I'm just pulling a Gamesky here. :yum: and talking about gear I no longer have. LOL.
Hehe,.. loved your description about moses coming out of desert of thin mids... :). I have this dreaded feeling whenever I buy new headphones.
The thin mid headphones tend to get a lot of 5 stars.... Luckily Scarbir . com and your reviews are spot on for me.
post-15329138
Post #16,165 of 26,811
Grayson73
Reactions: SoundChoice
post-15329149
Post #16,166 of 26,811
CocaCola15
Anyone have any luck with different inserts for Liberty 2 Pro? I love'em but can't keep them in my ear.
Looking for foam inserts they would accept, or the Christmas Tree shaped silicone...
I think the wings don't work for my ear, as well...
- RickIn Houston
I favor the Comply Smartcore Audio Pro foam tips with the L2P. I don't even use the wings, they bother me, and get a great, stable seal. Of course, you have to roll them up and let them expand, but I also think they improve the sound. Not cheap, $22 for 3 pair. But worth it to me.
post-15329199
Post #16,167 of 26,811
gibletzor
USA
USA
- RickIn Houston
I've been using JVC Spiral Dots with the small wings with mine.
post-15329284
Post #16,169 of 26,811
Timastyle
USA
USA
If I'm looking for a TWS with the SQ and signature of the SSK and effective transparency mode, which ones should I be looking at?
post-15329344
Post #16,170 of 26,811
Cretz42
USA
USA
Anyone want to trade a Tranya B530 for a Rimor set that I have straight-up?
Users Who Are Viewing This Thread (Users: 19, Guests: 37)
