Dsnuts
- Jun 20, 2011
its a big problem and can damage a driver, even tfz acceptit as a problem.
my friends are shocked by what I said and probably the sales of these headphones will be very bad.
I really liked my GK10 but GK80 sounds like a trash
Hold on before you judge them fully, those Zishan audio devices will not be a good match for the GK80. I can tell you that right now. I know those are something like 2-5 ohm out. Also I know it sounds counter intuitive but try the GK80 in single ended vs balanced. Reason I say that is because balanced out will double your output impedence meaning balanced out of the Zishan will be 4 - 10 ohms out. Which drastically changes how they sound.
I tried the GK80 on a 10 ohm out Acmee MF02S and I can tell you they sound nothing like how they sound on my Fiio M15 or DX300Max. It sounds like a completely different earphone.
Sensitivity of these earphones are what makes them all over the place. While you have them try all your sources and in single ended see how that might affect the sound you're hearing.
