1clearhead
- Apr 5, 2013
So, surprise, surprise!
They do make a Geek Wold GK12
About: Geek Wold GK12
I was able to get the Geek Wold GK12, which was delivered at my doorstep more than a week ago in China through Taobao's website by Geekfly. They look similar to the GK10, but without the heart shape. They don't come with the checkered black carbon fiber look as advertised below by Geekfly, but I'll take them anytime over the GK10's. After burning them in for 100 hours, I must admit, IMHO, they are in every way better than the GK10. The bass punches lower with enhanced sub-bass punch and texture and less mid-bass when compared to the GK10. The MID's has more air and transparency, while the hi-end details are incredibly better in every way. The GK12 has 12 drivers, while the GK10 has 10, and the GK80 has 8 drivers total. Below are more detailed SPEC's on all three.
SPECIFICATIONS:
Model: GK12
Driver configuration: 12 drivers' total
2 Ultra-high frequency piezoelectric ceramics
1 High Definition Midrange balanced armature
3 Super Bass graphene dynamic drivers
Panel: stable wood
Shell material: ABS+PC
Impedance: 7Ω
Sensitivity: 102dB
Frequency response range: 20-30kHz
Cable material: 4-strand silver-plated (non-detachable)
Connector: 2pin 0.78mm
Cable length: 1.2m
Price: Around $31 US dollars (199 Chinese yuan)
Model: GK10
Driver configuration: 10 drivers' total
1 High frequency balanced armature
1 Midrange 7mm graphene diaphragm dynamic driver
1 Bass 8mm dome titanium diaphragm dynamic driver
Panel: stable wood
Impedance: 8Ω
Sensitivity: 106dB
Cable material: 8-strand silver-plated
Cable length: 1.2m
Price: Around $48 US dollars
Model: GK80
Driver configuration: 8 drivers' total
1 MID to LOW frequency: 8mm Graphene diaphragm dynamic
Panel: carbon fiber panel
Impedance: 8Ω
Sensitivity: 106dB
Frequency response range: 20-35kHz
Cable material: 4-strand OFC
Cable length: 1.2m
Price: Around $47 US dollars
According to Geekfly, here's more about the GK12's below...
3 Graphene DD's!
PROS and CONS
PROS:
3 graphene dynamic drivers for enhanced bass. High-definition midrange with air and transparency. Enhanced upper hi-end and micro-details. Light, small and easy to wear in-ear units. Nice well-made silver cables. A good variety of silicone ear tips. Soft carry pouch. Plus, manual and warranty.
CONS:
Non-detachable cables (though they are stronger than the average 4-strand cables, IMHO).
Unfortunately, I can see that the GK12 only sells through Taobao. So, if you're able to pick one up, below is the link!
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.4da72e8d69upmy&id=656254073962&_u=4206rtltraeda3
One last note:
After knowing what the GK12 has to offer in sound quality alone when compared to the GK10, I don't know if I'll be getting the GK80 any time soon. Then again, curiosity killed the cat and it might just kill me, too. Overall, The GK10 just took a beating from my GK12's. TKO!
-Clear
SPECIFICATIONS:
Model: GK12
Panel: stable wood
Impedance: 7Ω
Sensitivity: 102dB
Cable length: 1.2m
Model: GK10
Panel: stable wood
Impedance: 8Ω
Sensitivity: 106dB
Cable length: 1.2m
Model: GK80
Impedance: 8Ω
Sensitivity: 106dB
Cable length: 1.2m
PROS and CONS
PROS:
CONS:
One last note:
-Clear
