Barusu Lamperouge
@Nimweth I suggest you try GK10 with Starlines. I believe you will be pleasantly surprised.
Nice avatar btw are those 840s or 440s?Glad that you're enjoying your sets @SpaceOperaVillain and @Barusu Lamperouge
With the CKX chock full of BAs that makes sense. soundstage with the stock tips seems pretty average. Hoping a tip roll will help. speaking of ...This GK10 reminds me of my CCA CKX but with wider stage and slight distance vocal.
That's a great call! I really like the Starlines and the KZ branded foams as well. Been listening on the GK stock tips so far.Medium bore - It's so far perfect for my usage. KZ Starlines are by far the best matched to them. Sub-bass livens up, mids bloom delicately and treble gets much needed bite. I think I've found my perfect setup in form of GK10 w/Starlines> BTR5
I held off on ordering a balanced cable until verifying the basic build quality, and regret it, now. 8-core 2.5mm already on its way. I am betting it'll be a noticeable difference since the btr3k isn't pushing much power single-ended. Like Barusu said tho - these pin sockets are evil lolI would recommend that you try to run them into a source with balanced ourput if you have chance and haven't already and see if treble gets airier,
For casual listening, BTR series and most modern BT amps are capable enough to faithfully judge an IEM.No offense, but you do realize that you judged (the IEM) using a BT connection and want to get better results by adding a better cable...the BT is compressed to begin with regardless of how it is called ... LDAC, AptHD or yaddi yadda...
Just sayin'...
Cheers.
Ha ha! I am already using them! There will be news about my set soon though....@Nimweth I suggest you try GK10 with Starlines. I believe you will be pleasantly surprised.
Just sayin'...
Cheers.
Unfortunately I don't actually know the model name, hahaha. That avatar was the default when I created my account years ago. I should probably change it to something more relevant to me, hmm...Nice avatar btw are those 840s or 440s?
I just tried swapping from the stock tips to large starlines this morning and it definitely opened up the top end. I hear more detail coming through sans EQ and the midbass bloat is less noticeable. Opinions are still developing but thus far I really like this set.
