faithguy19
ok, i already did that. but nothing??
Not sure what to tell you. It works fine for me. Very strange....
You really can't use Comply for comparison to other foam tips just because how much you can compress them. If you are using small size normally, I'll suggest you get the small Olive as well.
what size of Sony Hybrid tips can be use for SoundMagic e10?? Thanks
Originally Posted by ClieOS /img/forum/go_quote.gif
Yes, they are. But I remember Mark (mark1234?) said they are really good quality clone, plus you get to choose which size you want. I actually ordered a few from that eBayer (really fast response btw) and hopefully will receive them by next week.
i put down money for a set of these as well last week... i think it should be turning up anytime soon...
ok, so today i've gotten some mechanical pencils, their inner tubes are really stiff but i found some that are the right size to be forced onto my IEM nozzles... now im just waiting for the glue holding them to the P series to dry out...
also i have got different mechanical pencil with a thinner inner tube... same diameter as the nozzles of the IEM's ... i cut them up into small sections, just enough to fit the rest of the length of my triple flanges where my IEM nozzles dont reach... i think it improved their sound quality a little, abit more bearable to listen to, but nowhere as clear as the tips which came with my IEM's ...
::edit:: yup it works, the glue has dried up in my comply P's, the stiffness of the mechanical pencil tube is allowing all the sound through, and it also seems that its giving better seperation between the different high pitched sounds in my music
in the picture, the tips are laid out in this order... westone T100, SHE9850 T100, comply P foam with my tube glued into it, original comply P sleeve... and that is how it fits onto my SHE9850's
For both comfort and isolation, ntohing beat Comply. Olive isn't quite as comfortable, but still really good. silicone eartips just ain't as isolating or comfortable as the above two.
@sinquito - thanks for the tip but the erikaudioequip seller is gone from eBay, odd since he had 20,000+ feedback apparently !
