saisunil
Member of the Trade: Care Audio
- Sep 7, 2004
The custom molds provide perfect fit/seat for your ears. It takes the guessing/experimentation out of the picture. I do not run (unless I am getting late for subway
) - the fit is perfect. It takes a couple more seconds each to insert and remove the custom molds and they are washable. Of course they are not cheap.
I would not consider a home amp for IEMs (thought I have 1/8" headphone out along with 1/4" headphone out on Mapletree).
If you can get a hand on
Originally Posted by Caribou679 /img/forum/go_quote.gif So having custom made tips you have no problem with the seal? Is it good when you are on the move, like walking ,working etc,or only when being static, like on a couch or at the computer? When I used the Atrio the first times, my major drawbacks were with not having an adequate seal, did I loose time with that!!Now this is settle and I enjoy them everyday. Yes, I have been continuing my research on those amp and it is definitively on my wish list. (I'll see what my wife says about that!) Do you do any amp rolling? Also it is based in Canada, which is good for the ego. But the design, is it something else or what!! It just looks like this thing sounds so good!!!!!!!!!!!!!!!!! Will need RCA to 1/8 IC for input and output.(Think in future!!) regards, |
