Fostex x Massdrop TH-X00 Review
Feb 28, 2017 at 6:16 PM Post #9,856 of 12,089
  With regards to the case question, here is my experience:
  1. MrSpeakers case (https://mrspeakers.com/shop/3-accessories/headphone-case/):  As others have mentioned, they fit, but it is tight fit around the pivot / adjustment points.  Great fit for my Ethers (which have larger cups), but not ideal for the X00.
  2. Geekria EJB-0034-01 case (http://smile.amazon.com/dp/B00PDEZIPA):  Great fit with plenty of room for the cables.
  3. Slappa HardBody Pro case (http://smile.amazon.com/dp/B009NE7B06):  DOES NOT FIT
@gtb75  Hey how did you fit the th-x00 into the geekria case? Did you have to take out the stuffing/foam that was in there? The headphones doesn't fit within the spacing inside the foam.
Feb 28, 2017 at 9:48 PM Post #9,857 of 12,089
I didn't have to remove any foam. I just shrink the headband all the way down and put the headphones in with the slimmer portion of the ear pad in the foam insert.
Mar 1, 2017 at 10:04 AM Post #9,858 of 12,089
I wanted to know what peoples thoughts on the TH-X00 vs Alpha Prime. I'm sure the Primes will have more sound stage. How does the sub bass compare between the two? I'm currently getting my alpha dogs upgraded to Primes before he puts to rest of upgrading mad dogs/alpha dogs completely.
Mar 2, 2017 at 6:45 PM Post #9,859 of 12,089
Just got Fostex th600 and thx00 Purple Hearts. So far I like soundstage and airiness of th600 better, however to me thx00 PH has better low end. Will have to spend more time with both of them to see which one to keep.
Mar 3, 2017 at 9:21 AM Post #9,862 of 12,089
From the smaller opening pads THX00, to TH-610, Denon AHD5000/7000 and last TH-600/900 (pads) the sound changes very much. The bigger the opening the more "open and free" the mid range and the treble sounds to me. Perhaps with some addition to the treble, where the amplification seems to have a great influence too on the perceived harshness of the treble. Also bass level is less high with the larger openings in the mid bass range, which to me sounds more neutral and good. In a way the original THX00 pads sound muffled to me.
I tried a Nuforce HA-200 which I liked, strong bass with clean mids and warmth (ie, not harsh) and a lot of detail too. Now I am waiting for the TEAC HA501 to arrive!
Mar 3, 2017 at 9:27 AM Post #9,863 of 12,089
I'm driving my cans with Schiit Modi Multibit and Magni 2 uber and they don't sound harsh to me either.
Mar 4, 2017 at 3:46 AM Post #9,864 of 12,089
Recomendations on pads with bigger opening  for the THX00 ?
Mar 4, 2017 at 9:51 AM Post #9,867 of 12,089
