Fostex annouced yesterday that this "
HP-P1" would be released on Feb. 28.
News release (PDF, Japanese)
Price: 68250YEN (815USD)
DAC chip: AKM AK4480
Charging time: 5 hours
Play time: 7 hours
75x25x130mm
260g
Head phone output terminal (stereo mini- jack) installed capacity: 80mW + 80mW (32 Ω loads)
conformity load impedance: 16 Ω or more
Frequency response: 20Hz~20kHz ± 0.3dB (at 32 Ω loads and 80mW output), THD+N: 0.01% or less (at 1kHz and 32 Ω load, 50mW output)
[LINE OUT] output terminal (stereo mini- jack) installed capacity level: 2Vrms (0DBFS)
frequency characteristic: 20Hz~20kHz ± 0.3dB, THD+N: 0.002% or less (0DBFS)
Analog input terminal (stereo mini- jack) largest input: Approximately 3Vrms
[S/PDIF] output terminal (optical) S/PDIF format (IEC 60958-3, JEITA CPR-1205)
USB connector for Dock cable (for iPod/iPhone connection): USB Type A
[DC-IN] terminal: USB Mini Type B
[FILTER] Change-over Switch: [shiyapuroruohu] filter/[minimamudeirei] filter
<=== wut?
Power source: Built-in lithium ion electric battery - Charge time: Approximately 5 hours (HP-P1 power source OFF) - Continuous action time: Approximately 7 hours (with an iPod connected and headphone output 32Ω, normal temperature)
External size: 75 (width) x 25 (height, the feet not to be included) x 130 (depth, projection ones are included) mm
Weight: Approximately 260g
Accessories: Dock connector USB cable and USB cable for charge, carrying case, instruction manual
