MykeHBM
Just been offered a voucher for Monoprice Monolith THX AAA amp that reduces the price by £150 sounds like a steal but wondering if its worth getting for the argons as on my iFi zen can they seem to have a lot of treble spike.
ZMF oval suedeSo was at a store today and demoed 3 Hifiman (Sundara, XS and RE9), Focal Clear (older version) and the T60RP.
The store was using a Naim streaming amp for source.
I wanted the clear but definitely out of my price range (specially I'll only be using it while working from home) and I felt the Fostex is built better and more comfortable (feels like I have very supple pillows on my ears) than the Hifimans. Sound seems on par I think.
In saying that, I'm hoping the community can recommend quality+deeper+supple pads to create more room for my ear.
Thanks
Any reason to select the suede over the offer materials? ThanksZMF oval suede
Comfort and a wide open sound. The suede doesn't absorb so much as pass through the energy. It makes for a uniquely wide-open listening experience is a perfect long-lasting comfort.Any reason to select the suede over the offer materials? Thanks
Yes, cup dimensions are the same.can I use pads designed for the t50rp mk3 on these phones? thanks again
thanks. i've looked around the net and cannot find the pad dimensions for the T60. (plenty of replacement pads specifically mention only the T50)Yes, cup dimensions are the same.
Also want recommended/inexpensive replacement cables? Thanks again
link to --your-- cable? thanksLots of modding has been done, history of it in-fact with T50/T60 Fostex series cans/drivers etc... If you read through the thread (or search the net) I'm sure you'll get a few idea's. I love my T60's 'n am enjoying them this evening (will always be one of my fav cans), I've done basic mods to these + my own custom pad's 'n silver/rhodium cable etc... My take on how I enjoy them currently......
I don't know about cheap cables I tried a couple but they were faulty/wrong config for these cans..... I have OEM SE and BAL, I prefer my cable no-contest but my cable my not be " inexpensive " as that's subjective....
also, what are the "basic mods"? I've back read and it seems there's no one authorative list. thanks!
