kintsaki
Guys, before I return my squeaky T60 in a few days, I also got a T40 (Mark 3) yesterday and so far I prefer the T40 (which is the closed back version).
I have had a look inside both and the T40 is the only one that has an attempt at some baffle dampening inside. The T40 seems to have the same baffle foam ring as the T20 photo taken by Kintsaki.
I will experiment more in the next few days by changing pads and rings and see if my view changes.
I paid £114 for the T40 and £280 (now £299) for the T60 on Amazon UK.
I am new to the Fostex RP series so any advice or opinion is welcome.
Overall I think that the T60 is decent but its sound is more on the closed back side for me and the T40 is a little more closed in but sounds more engaging, natural and intimate. I also like the benefits of closed backs on many occasions and that is why I am still searching.
If I keep the T40, I would probably change the pads (which are not as bad as I have read) and put real leather pads on it as well as some foam on the headband and possibly some blue tack dampening on the inside of the cups.
Also, does anyone know if the T60 pads are real leather as I am a little doubtful?
I am also a bit skeptical that the wood cups on the T60 make an audible difference other than having natural dampening built it?
Controversial indeed!!!
Thank you for this extremely important post. My wife agrees with your observations on the t40 vs t60. Her IQ exceeds mine by 50 points.
I went back and listen to the t60 and t20 again and I can only say I agree with your initial impressions and her. To make things more interesting
I have two t20's my second one was purchased a week ago and it is this second one that really shines even though the other the 12 month old
is also close to your description. Am I to conclude that the new t20/t40/t50 has moved to the "mk4" driver??? And it does not need the XTI to
bring out those differences although the XTI truly illustrates them especially the ones on the extreme ends.
Bass is layered better and treble is refined airy but not crashing at the very top thus presenting finer detail in a romantic way. The t60 hot treble is easily solved with placing some foam inside the pads but layering of the bass does not even with the t20 baffle ring. Yes said more engaging and that is exactly what my wife said and what I felt myself.
I have always been of the opinion that open back is not the right solution hence the failure of Stax to beat the ESp-9.. Larger closed enclosure is the answer. I am working with a 3d printer shop to make a ring to enlarge the enclosure. On the issue of wood it is not quite there because of the plastic baffle. The Smeggy with the ring and the mk2 driver is very very woody and engaging but it badly needs the back wave reinforcement on which I am working on. It is completely closed but the soundstage is literally double that of the t60 and most important of all each note each instrument has twice the body the duration and the layers. It is so extreme that I have some ideas to make it sound like a speaker. Mind you I have owned the Stax Sigma, , the Stax O2, the AKG K-1000 and the Sennheiser 800s for years and they were all just an elegant concept that failed to deliver and you know I was using proper source and amp.
Pads are not real if you buy a piece of real leather you will see what I mean. Most pads are plastic painted leather. I am making my own pads from
true leather and NASA foam, just the leather material costs me wholesale 50$. And leather in Greece is cheap.
Good luck and take your time "We Have All The Time On The World".
