brokentofu
- Aug 16, 2015
What kind of damping have people had cup side on the mk3? Is sorbothane still a good option
How are memory foam pads? I was looking at the Bose QC25 ones, working on my fisrt mod of the mk2 and trying to close them a bit. By the way. is there a way to know if some pads are compatible with another headset? Couldn't they make sizes like s, m, l, xl or they're generally all fitting to one another?
As regards the "ballast", has anyone ever tried oenological mastic?
Never seen it in these forums. What is it? You'll be the first to report its effects.
Ok, maybe the basses are still a bit low but that's a thing about these cans I guess.
Make a vent in the material you're using aligned with the cup vent (maybe a paper punch will work). You'll get more bass.
Few days later.....
I didn't really know what to do except trying the oenological mastic and do one step at a time. So first step has been just add ballast and see if anything changed and oh boy it did change. I've been really impressed by how remarkable was the difference. All that sort of muddyness was gone, sounds were way better separated and detailed but it was very far from being perfect. Especially the voices gained so much presence in the scene that I was a little disappointed since in fact it seemed like all the other mids and especially basses went too much behind.
So I needed some "opening" and all I imagined to do was get rid of that white cover on the back of the speakers (dunno if it's the correct term for planar cans....) and boy I had some opening!
Pics or it didn't happen? Mkay
Again I've been blasted by how huge was the change. Guitars and drums in particular went from "neat" to "OMG" level of awesomeness. The beginning of Free Four in Obscured by Clouds, any song in Dub Side of The Moon or even the infamous Live and Let Die by Guns n Roses were near mistycal experiences. But it was all too loud now as if all the instrumets were racing to get on top of each other and yeah it was all "too wide open".
it's not clear whether you are modding one of the new mk3 models or an older version
also - your post will have more credibility if you do not put a picture of an evildoer ********* who wrecked our country at the bottom of it
It's mk2 all the way. Actually it may even be no-mk-at-all. That's probably why it costed 100€ only instead of the 140 for all the others mk2. No clue really. Sure it's no mk3.
As for the evildoer, looks like sometime history makes you repeat the unlearned mistakes. Aaahh Murica!
