Dr Jekyll
- Oct 30, 2015
If you can be more specific about what you want I can take a crack at it, are you looking for something that fits the original t50rp cup that makes it easier to change pads? Is there a particular set of pads you'd like compatibility with because I've made baffles in the past which will fit brainwavzs pads (especially angled)
I have a set of Alpha Pads I'd really like it to work with. I do have access to a 3D printer, but PM me your rates anyway. And yeah, pretty much just a lip that fits on top of the existing baffle of the T50RP that I can them properly fit my pads around.
