Sam21
- Sep 25, 2013
magni 2 uber can drive it, you are gonna need at least 700 mW at 50 ohms, check the amp's power ratings.
Thanks, I will keep that in mind.
anyone know where to buy [COLOR=333333]Shure 1540 Pads [/COLOR]in europe, for a good price?
any other recommendation for ear pads?
anyone know where to buy Shure 1540 Pads in europe, for a good price?
AFAIK, and I looked in multiple forums, IRC channels and IRC communities it appears that they aren't available on any Shure reseller/partner in Europe that sells them. I personally checked all the resellers/partners mentioned on Shure's site in the UK, Germany and Spain and I couldn't find any that had it so I guess the only way would be to import them from the US website or Amazon.
I ended up settling for buying the Brainwavz hybrid pads from amazon.co.uk since they're readily available, come from a reliable source and are much cheaper and easier to obtain. If you want a link straight to the pads click here.
How does it sound with Brainwavz Hybrid ?
do any of you, experience crackling sounds on higher volumes?
is it probably because my gear, doesnt produce enough of power?
does any of you get some bad clipping or such, or any mistreated sound, even with good gear?
How would I know if an amp will be able to drive these boys?
anyone recommending a tube amp? or is it too much of a hassle?
are there any really good audiophile amplifiers for speakers rca, and headphones that can be bought around 250 euro's(or a bit more)?
