I don't have Arche but I heard before that was a known issue of Arche.Has there been a recent firmware update ? Could you tell what the firmware update number is ? Mine is 01.01.08 I have to turn mine on and off a couple of times (not good for electronics) to make it connect to a computer or a DAP either with USB or Toslink. It's a bug that Focal know about and are supposed to be sorting it.
Focal Utopia General Discussion
- Thread starter Allanmarcus
Gadget67
- May 28, 2012
I have discovered that the connection sequence is important. The first step is to turn on the Arche first and wait until the default screen appears before connecting a DAP with USB. Otherwise connections are random and work sometimes but not others. Obviously that’s a bug and they are aware of it but for now I can live with it.Has there been a recent firmware update ? Could you tell what the firmware update number is ? Mine is 01.01.08 I have to turn mine on and off a couple of times (not good for electronics) to make it connect to a computer or a DAP either with USB or Toslink. It's a bug that Focal know about and are supposed to be sorting it.
PrTv
Speaking of pads, as Focal's original pads are forbiddingly expensive (around USD 400 where I live), has anyone tried replacement pads from Dekoni?
https://dekoniaudio.com/filter/?product_cat=utopia&product_cat=utopia
They seem nice. Actually I ordered a pair for my LCD X but have yet to receive it. It'd be great if we can have some reasonable alternatives.
Gadget67
- May 28, 2012
Focal Utopia replacement pads are available from Moon Audio and their current pricing is $249 a pair. Still expensive but better than $400!Speaking of pads, as Focal's original pads are forbiddingly expensive (around USD 400 where I live), has anyone tried replacement pads from Dekoni?
https://www.moon-audio.com/focal-utopia-headphones-earpads-pair.html
I would love to read your comparison to the Berkeley Reference. Tks.It took a bit work to get the microRendu working with the Arche, but after updating the Arche firmware and setting it up as a Custom DAC on the microRend, it works perfectly, but limited to only to sample rate 192khz. Im quite positively surprised with just how good the Arch/Utopias sounds. At some point I will try the Arche just as an amp with my Berkeley Reference DAC. The Berkeley DAC surely was better than the Sony. That said, the Utopias on the Arche are extremely synergistic. Truly a match.
I just got Utopia while ago. It sounds awesome as expected but originally there was a slight channel imbalance. I measured it to be sure. There was indeed measured imbalance starting from 200hz. It was nothing drastic mostly it was only 1db but would go allmost to 3db in the higher frequencies.
Because bass was unaffected I thought it could not be an issue with seal/pads being installed wrong but I took them out anyway.
On the left pad it can be seen that the imprint does not go full circle. So obviously the pad was not in place properly. I put the pads back in reversed cups and channel imbalance was gone!
Nothing was suggesting poor pad installation, it was well in place and looked as it should.
LCMusicLover
I tried the fenestrages lambskin — didn’t like them:Speaking of pads, as Focal's original pads are forbiddingly expensive (around USD 400 where I live), has anyone tried replacement pads from Dekoni?
https://www.head-fi.org/threads/focal-utopia-general-discussion.811273/post-14485897
PrTv
Thanks for your feedback... better stick with stock then.I tried the fenestrages lambskin — didn’t like them:
LCMusicLover
Just FYI, Elex pads are better, sound-wise, although nowhere near as nice feeling-wise vs stock.Thanks for your feedback... better stick with stock then.
I may have mentioned this before but with the issue on the current firmware, to the Focal Arche crew - I use the Sabrent HB-UM43 USB hub which has switches on it. A quick on and off flick on the USB switch for the port it is plugged into and the Arche begins to work. No need to mess with powering up and down the Arche or physically going to the back of the Arche to sever the USB connection. Only £10 in the UK to resolve this frustrating headache.Has there been a recent firmware update ? Could you tell what the firmware update number is ? Mine is 01.01.08 I have to turn mine on and off a couple of times (not good for electronics) to make it connect to a computer or a DAP either with USB or Toslink. It's a bug that Focal know about and are supposed to be sorting it.
Trust me, i've all different all different sequences (you and me have had this conversation before) and it doesn't work first time. I think maybe it came on twice first time since i've had it (August).I have discovered that the connection sequence is important. The first step is to turn on the Arche first and wait until the default screen appears before connecting a DAP with USB. Otherwise connections are random and work sometimes but not others. Obviously that’s a bug and they are aware of it but for now I can live with it.
I've got about four different hubs and whether i use them or not, it's the same... doesn't connect first time. I can connect or disconnect easily as the same as the hub you mention but doesn't make any difference.I may have mentioned this before but with the issue on the current firmware, to the Focal Arche crew - I use the Sabrent HB-UM43 USB hub which has switches on it. A quick on and off flick on the USB switch for the port it is plugged into and the Arche begins to work. No need to mess with powering up and down the Arche or physically going to the back of the Arche to sever the USB connection. Only £10 in the UK to resolve this frustrating headache.
The Berkeley is a better DAC, but it’s 10x the price, plus an additional device if you want USB. So it should be better. There is an added silence between notes on the Berkeley, you hear more detail, but with no harshness at all.I would love to read your comparison to the Berkeley Reference. Tks.
Thank you. How do you figure 10X the price? I thought they were within a few thousand of each other? I realize no headphone amp on the Berkeley. Tks.The Berkeley is a better DAC, but it’s 10x the price, plus an additional device if you want USB. So it should be better. There is an added silence between notes on the Berkeley, you hear more detail, but with no harshness at all.
Per my prior update the Berkeley Ref 3 lists for $22k vs list of $17,500 for the Bartok, no?The Berkeley is a better DAC, but it’s 10x the price, plus an additional device if you want USB. So it should be better. There is an added silence between notes on the Berkeley, you hear more detail, but with no harshness at all.
I was hoping Bartok might match it in sound quality. Tks.
Total: 13 (members: 0, guests: 13)
