Don't forget the magic pebbles. It's clearly been shown these are pebbles.Better use that money on upgrading the cable of the Focal Utopia rather than buying an amplifier. It seems that the stock cable is holding back the Focal Utopia quite surprisingly.
The H2 has plenty of power to drive the Utopia. If you get high end amp (and many would suggest avoiding AudioGD), you will likely eek out a
Will the sound be different with an H2 and amp, vs just the H2? Possibly. Depends on the amp and the tubes (if there are any). Will the sound be different with a different cable? Unless you get pure silver, which I did, probably not worth the money. A pure silver cable made the Utopia way too brittle sounding to me.
I recently made a pure silver/copper hybrid cable that I will test on the Utopia when head stops exploding every ten minutes (yes, it's quite messy).
You have to ask yourself, are you happy with the sound? If not, what is missing? Can a cable "fix" what is missing" Can an amp? Can different headphones? A different DAC? A Schiit Eitr (or better transport)?
Hell, everything I've read points to the Eitr being the best bang for the buck for a system upgrade, unless you want to spend hundreds more on more exotic stuff like a Soundware D100
Again, what are you missing? If you want better, then get a Dave or a TT (if you like that sound) or a Yggy and an Aficionado or high end DNA amp. Have you heard the McIntosh amp Jason loves with the Utopia? D1100 I think?
