LCMusicLover
Some of us can’t use loudspeakers.i can't relate to that criticism of the utopia. if i want to experience soundstage then i'll listen to loudspeakers…
I think the Utopia is a superb headphone, but for me, the Susvara just does everything somewhat better, while doing nothing worse. I rate the Utopia's soundstage size as average, and not one of its stronger points. The album in question isn't available on Tidal, so couldn't check it out specifically.
Have a listen to this album, and this song in particular.
It sounds amazing with the Utopia. Love the strong central imaging and peripherally placed elements going on at the same time. I listen to this song/album and wonder how people say the soundstage width on the utopia is small. Love the snappiness and it is just so detailed and pinpoint. Plus I'm not getting any harshness at all. Just the right amount of grittiness when needed. Awesome bass punch and texture/detail. Haunting realism..
Solidifies the Utopia as my number 1 favourite headphone. It was my first totl headphone and I could have just stopped there.
*edit
And check out the percussions and imaging on "Across from My Window" on the same album.
there are headphones with much larger soundstages...abyss or sr1a and even susvara...loudspeakers are not the only comparison...that said some people like the more intimate soundstage thats why they make so many different HP's...choose what you like best...personally I like a bigger soundstagei can't relate to that criticism of the utopia. if i want to experience soundstage then i'll listen to loudspeakers.
i guess i should add that i find the utopia's 'headstage' is recording dependent.
We all hear this stuff differently, obviously.
The only thing i want to achieve with Utopias is to improve bass impact & thicken the sound without loosing on technical side. Tube amplifier should help me here, but I'm a bit lost with options and worried to end up with a sidegrade.
That album is not on Tidal, at least for me. Perhaps there are licensing issues within the US?
Ah.. this album is on both qobuz and tidal. Try give it another search?
I agree the susvara is the technically superior headphone in many aspects.
I actually find the soundstage on utopia really good. And I also find the soundstage on these headphones easier to ascertain and visualize in my mind, perhaps due to its very accurate imaging even with elements in the periphery.
On a side note, Utopia with the sa-1 is great but Utopia with tubes is heavenly!
They still are.That album is not on Tidal, at least for me. Perhaps there are licensing issues within the US?
On another note, while listening to my Utopias at low volume just earlier, the left channel suddenly went out! I swapped the cables channel-wise and it's definitely the left driver. Never had any issues previously.
Question: does anyone know the best way to get these serviced if I live in California? I bought them from @tsav roughly five years ago, but I'm pretty sure they're no longer a Focal dealer. Thanks in advance for any guidance!
i appreciate that but it's beside the point, which is that headphones don't create soundstages - loudspeakers doSome of us can’t use loudspeakers.
i agree that there are headphones with more spacious presentations than the utopia such as the abyss and the hd800 but as i said in my post, if i want to experience the illusion of a soundstage then i'll listen to loudspeakers - not headphones. nor do i share the view that the utopia sounds 'small' or 'closed-in' as some people have described it - it sounds like a headphone. and as i also said in my post, i find that the utopia's 'headstage' (for want of a better descriptor) does vary depending on the recording - ymmv.there are headphones with much larger soundstages...abyss or sr1a and even susvara...loudspeakers are not the only comparison...that said some people like the more intimate soundstage thats why they make so many different HP's...choose what you like best...personally I like a bigger soundstage
Somehow Utopia responds poorly to EQ in my scenario. Not sure how EQ could help me to bring Utopias timbre towards organic side like HD650 and thicken it's sound signature. There is an idea to replace my Qutest to R2R based dac and purchase budget tube amp first prior to blowing $$$ for something serious.Have u tried using EQ with the Utopia?
I have a few settings I keep ready on Roon, but I dont use them very often. They're from Oratory and Crinacle and tuned for Harman curve I think. If I'm on the tube amp, the bass gets a bit excessive. Perhaps better with SS amps.
not sure how changing a dac or an amp is going to change the timbre of the utopia to your satisfaction but good luck with it
