up late
- Feb 19, 2013
does it "seal properly on all heads"?no, similar balance to the hd600, with more midrange detail.
I've heard that the Stellia has sealing issues, but I literally cant seem to have any. Even if I hold the cans to my head, the bass response really doesn't change. I find them to be bass-light, not heavy at all. At least for R&B type music with thumping bass. For anything else it has plenty of bass. I think its just that the drivers are fast and don't reverb with bass thump like I'm used to for bass thumps.
Could it be that I just never get a seal?
Love the way they sound if so. LOL
They leak. Not that bad, but more than other (more affordable) closed backs I had (B&W P7 or Oppo PM3). That being said of course it depends on your listening volume.Im not sure if this has mentioned before (theres no way I'm reading through 68 pages), but how do the stellias perform in terms of sound leakage? I rarely have more than 2 hours of listening all alone, so this is rather make or break.
Headphones and Personal Audio with Pitch Perfect Service.
Stay updated on Bloom Audio at their sponsor profile on Head-Fi.
Thanks. Can i just ask what song you were listening to in your youtube review?Leakage is minimal. The pads are cushy and the clamp is not super tight, so some sound will leak.
ThanksThey leak. Not that bad, but more than other (more affordable) closed backs I had (B&W P7 or Oppo PM3). That being said of course it depends on your listening volume.
I noticed that too. It’s definitely Redman.joshua redman?
