I have the Hugo 2 and Elegia's also. I think the Elegia's are very detailed but slightly warm sounding. I like that because it makes them a pretty good all around headphone with a variety of different genres of music. The H2 is fairly neutral and brings out the details in Elegia's, but I like them a lot more on my Burson 3XR. On the wrong amp the Elegia's midrange can sound congested like it does on my Liquid Platinum. I don't like the pairing with the current tubes I have.I did demo the Elegia (stock cable) with my Chord Hugo2. It was a little warm for my taste, but definitely had real presence and detail. For a closed headphone I found it both revealing and spacious.
Focal Elegia - what do you think?
- Thread starter Hoegaardener70
- Tags
- focal focal elegia
rickydenim
- Jan 23, 2015
Proud new owner of the Elegia! Picked these up on Friday and didn't have much time to sit and listen so had them pumping some tunes for a few days to help break them in. I got these for my office to use with my Topping DX3 Pro.
Coming from my Momentum 2.0 (over-ear wired) phones these are a HUGE upgrade. Based on some reading I was doing I thought I'd be missing the low-end but honestly I love what these do there so much more. Fast, punchy with great timing. Not really missing the over-emphasized bass that Momentum have at all to be honest.
I've ordered a pretty cheap New Neomusicia cable from Amazon as this will be less intrusive in the office, will see how that goes before I drop some bigger $.
Keen to spend some more time with these! I also gave them a go with my portable Oppo HA-2 and tested out the bass-boost too. Seems to work well enough on these, couldn't do with the Momentum. But think I would only use it for some content really.
Now to find a sexy headphone stand!
Thank you for taking the time to respond My budget is under £1000, however I am reluctant to go used/ refurb (I just don't like taking risks, prefer the safety of a warranty with new purchases). Will have a look at the Aeons. My shortlist now consists of (in order of preference (before trying them out):What's your price range? I can't name a single closed back that I'd recommend over the Elegia under the $700 price point that it seems to be going for right now. If you're willing to spend closer to $1000 and can find a used/refurb Audeze XC, those are technically strong too, leaning more towards the warm/dark tonality, versus Elegia which tilts brighter.
I'd maybe try out the Aeon Closed 2 (hear good things about them, I've only heard the first gen... they were good but not as good as the Elegia and lacked dynamicsm... I hear the new version is a significant improvement in that department). I can't flat out recommend it as I haven't tried it, but if you demo it, may be a good place to start.
1. Focal Elegia (everything looks good about this option)
2. Meze 99 Classics with upgraded balanced cable
3. Aeon Closed 2
Will get a demo sorted out now, can't wait!
Thanks all for providing your feedback and advice, this forum is fantastic
GiullianSN
That is actually a great shortlist for this price range. Just reminded of another option if you want to add another one to your short list, Beyerdynamic DT1770 Pro. 4 totally different sound signatures that may cover your needs and make you happy.Thank you for taking the time to respond My budget is under £1000, however I am reluctant to go used/ refurb (I just don't like taking risks, prefer the safety of a warranty with new purchases). Will have a look at the Aeons. My shortlist now consists of (in order of preference (before trying them out):
3. Aeon Closed 2
Awesome there the merrier! May have to book a whole day off work to get this demo in, but what a great day it will be! The shortlist is now:That is actually a great shortlist for this price range. Just reminded of another option if you want to add another one to your short list, Beyerdynamic DT1770 Pro. 4 totally different sound signatures that may cover your needs and make you happy.
3. Aeon Closed 2
4. Beyerdynamic DT1770 Pro
Thanks again
chomskyan
Turns out the Meze cable was fine all along! The culprit was balanced output of the iFi Zen DAC. I had received the Zen the same day, and tested it with the Meze. It was my only 4.4mm option at the time. I had concluded the cable was at fault, due to both the rear and front Zen balanced ports outputting right-side only. I assumed the rear and front ports of the Zen were on different channels/circuits(?), it seems they were on the same.
Today the 3.5mm male to 4.4mm female adapter arrived. Seems to be of good quality, far as I can tell.
My current chain:
Roon ⇾ Audioquest Dragonfly Cobalt ⇾ Youkamoo 3.5mm M to 4.mm F ⇾ Meze 99 Classics 4.4mm Cable ⇾ Focal Elegia
Listening to Tidal 44.1 or MQA tracks, this setup is finally revealing the sound I've been reading about!
The cable and adapter are both balanced, the Cobalt is not. This doesn't seem to be an issue, as far as I can tell.
Next up is the RME ADI-2
My current chain:
Interesting stuff... if you end up getting the ADI-2 you'll be getting a LOT of power (comparatively) through XLR balanced connection for sure.Turns out the Meze cable was fine all along! The culprit was balanced output of the iFi Zen DAC. I had received the Zen the same day, and tested it with the Meze. It was my only 4.4mm option at the time. I had concluded the cable was at fault, due to both the rear and front Zen balanced ports outputting right-side only. I assumed the rear and front ports of the Zen were on different channels/circuits(?), it seems they were on the same.
My current chain:
chomskyan
Most worried about finding the right XLR cable that will work with the Elegia, probably gonna have to get a custom Corpse
Seems like I might be fine with the front SE outputs though, since the Elegias don't need a lot of power. What do you think?
Oh yea single ended will be plenty IMO. The Elegia isn't terribly hard to drive at all, hell it powers up well even from my tiny Dragonfly Red. That being said, not to sure about the balanced 4.4 on the ADI. I might suggest you go for a 1/4" though, if you're worried about XLR. There are plenty of solid 1/4" cables for the elegia that wont cost you much over $50, if that .Most worried about finding the right XLR cable that will work with the Elegia, probably gonna have to get a custom Corpse
GiullianSN
Just sharing here. Found the Meze Cable in 3m, but unfortunately they don't ship to AUS.
https://www.amazon.com/3m-Cable-Classics-Walnut-Gold/dp/B0756FZHTT?th=1
jestercow
There is also a 1.5m cable with inline controls:
https://www.amazon.com/dp/B085P23JCY/ref=cm_sw_r_cp_api_i_DYz4EbECEQ8B1
I have both and can confirm these Meze cables are no joke!
GiullianSN
too bad they don't ship to AUS through Amazon.
chomskyan
How did I not find this.. Amazon's search system is such a joke...
Hello guys I got redirected here.
Can someone help me with this topic?
I desperately need durable focal earpads for my elegia.
Dekoni Elite Sheepskin.Hello guys I got redirected here.
Total: 9 (members: 0, guests: 9)
