kinkling
- Jan 8, 2005
Well, mine finally showed up. I've been burning them in for three days now, and only have one weirdness. When I play my other lower impedance headphones on my Fiio M11, the volume stays around 75. When I play balanced headphones from it, volume is fine around 50. So I was doing some A/Bing, and when I plugged in the Elegias using the Meze 99 2.5mm balanced cable, output was lower than I expected. I had to crank it to 75, which I found strange, because they are only 35ohm/105dB/mW and pretty easy to drive on paper. All connections seemed to be solid, and it sounded fine, but I thought it was odd. My 32ohm/107dB/mW IEMS play much louder through the same input.
