HardstyleLoco96
- Jan 21, 2014
Hi guys! Any recommendation to drive the Elegia? Also, cable recommendation?
I can say the Elegia is driven very easily, but a good dac/amp will obviously be the way to go. Chord Mojo, very nice pairing. The warmth of the Mojo will help add a touch of thickness to the sound. If you have EQ, try adding 1db at 31 and 62 and 1.5 db at 125 and 250. You should be set. And I rec the E1DA 9038s. Extremely portable, heaps of power. Extremely good measurements. Amazingly good dac. And the price is seriously hard to beat. I honestly can't think of anything else. I used to use my Woo Audio WA7 fireflies dac/amp. But ever since getting the E1DA 9038s. I just use the WA7 every now and then. It's still a better dac/amp. But truthfully, not by much. The 9038s has insane performance for the price in such a small package. I also rec a Fiio Q5S or you could try the E1DA powerdac V2. But my pick out if all those is the E1DA 9038s. And for a cable rec, try Dyson Audio. They arent crazy expensive but amazing quality. If you want something a bit more higher end, you can give Forza audio works or Cardas cables a go. But I say go for Dyson Audio. Very very nice cablesPerhaps, with a chord mojo...?
How does it pair with a chord mojo?
I own a mojo and I am thinking about buying the elegia
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
