HardstyleLoco96
- Jan 21, 2014
Just ordered myself a Cardas Parsec cable with dual 3.5 connectors and 2.5 balanced termination for the Elegia. I'll see how it is
Using same cable, with XLR termination. Also using silver plated cable, with Pentaconn termination. Satisfied with both cables. I only use the standard cable with Mojo, which is not often.I had a custom Grave Digger cable from Corpse Cable made for $180 that is very good with the Elegia. It uses Cardas Audio cable construction.
My elegia is dual mono from stock.Do you notice any difference in the sound signature? This Meze cable is dual 3.5mm mono, while the Elegia is dual stereo. I also asked about this before in the Beyer thread (Beyer headphones are also similar to Focal) and somebody warned me against getting this cable, which was designed for the Meze 99 series, to be used on dual-3.5 stereo connector cans. Admittedly I am not exactly sure what the downsides could be on the technical side of thing, but some folks reported changes in frequency responses, etc. Just double check to make sure that the cable doesn't ruin the driver in long-term use.
I have one of these, in a 1.5m 3.5 mm Neutirk unbalanced flavour: https://oidiosound.co.uk/mongrel-focal-elear.html
Lovely cable, very well made. Once back in stock, I'm going to go for the Pellucid plus in 2.5mm balanced for my A&K Kann.
I haven't auditioned Kann yet. Read positive reviews though. Currently listening to Elegia on WM1A. Coldplay in HD (192 kHz/ 24 bit) is just sublime......I am using my Elegia on the Kann Cube as well. A perfect pairing!
Technically, I fail to see how it could change anything anyway
That’s good to know, i hasn’t tested unabridged . I have been a bit more thorough in testing different wire in various weights and configurations. I’ve made around 25/ 30 different recipes testing them with stellias and elegia with hugo2 and sotma 200 neo ultra streamer. My general findings are that all Ofc cables no matter the cost are much of a muchness. The most noticeable improvements come with upocc copper or silver. The copper variant is the best bang for buck, with 4x 22awg coming i at £60 and outperforming shop bought Ofc at any price not to mention the horrible focal stock cables. The upocc silver is the best wire I’ve tried. Gauge is important if you want to get all the benefits 22awg or heavier per conductor. I use a 4 x 22 core Neotech upocc silver witb both the elegia an stellia. Obvs the cable doesn’t have a sound of its own, it’s just how much more transparent it is that defines its effect. The stellia unsurprisingly benefit most with improvements in staging, separation, resolution and dynamism all with a lovely lquiditity and natural smoothness of tone. The performance improvements are along the same lines but unsurprisingly less pronounced as they’re not as resolving as the stellia. Like-wise if I switch down Dac to the df cobalt with the stellia, the improvements again become harder to discern than with H2 or Tt2. If I hadn’t already made the the upocc silver cables for the stellia I’m not sure I’d bother for the elegia. I’d recommend a 4 core Neotech upocc copper and be confident providing your partnering kit is at similar level, that you’ll hear a Noticeable improvement over the stock cable in most areas of performanceI checked further after posting, there is no need to bridge ring and sleeve if using a stereo connector, it seems to be bridged in the headphones (tested with a male / male stereo jack cable connected and multimeter).
I made 2 cables for mine, one is bridged and for the second one I didn't bother, just connected signal to tip and negative to sleeve, works just fine.
Sonically I'm not picky when it comes to cables, apart from balanced / SE I cannot seem to tell significant differences.
My made my main cable using 3.5mm connectors in this way as there is a far greater choice of aftermarket plugs and i wanted rhodium plated.
