Soundizer
- Dec 29, 2015
My set up. Cannot decide on DAC/AMP.
maybe iFi Diablo?
maybe iFi Diablo?
iFi Diablo?
Yes was considering it, but a review stated it is a bit analytical for brighter headphones? What do you think?If portability is not as Important for you, the clarity of the RME ADI-2 FS (or Pro FS) match perfectly with the voicing of the Clear MG.
The Clear Mg for the most part is a warm headphone and I find it benefits from brighter sources. The nice thing with the RME is it has a 5 band parametric eq. I have to eq my clear mg to enjoy as I find the treble to dark for me.Yes was considering it, but a review stated it is a bit analytical for brighter headphones? What do you think?
I think it depends on the perspective, for me "warmer" sounding DAC/AMP's have a "sound" where the ADI-2 Pro FS falls into the transparent category. I have no trouble using the RME with brighter Beyerdynamic's for example, but I usually EQ them as I find that bright headphones alter the timber of acoustic instruments too much for my liking.Yes was considering it, but a review stated it is a bit analytical for brighter headphones? What do you think?
maybe iFi Diablo?
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Can you recommend a 4pin xlr to 4.4 adapter as i like to use the Clear MG stock XLR cable to Diablo.All I can say is that it would work
Hi,Can you recommend a 4pin xlr to 4.4 adapter as i like to use the Clear MG stock XLR cable to Diablo.
I ordered one of these from Amazon UK,
https://www.amazon.co.uk/gp/product/B07MNMNP3K/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Hope that helps.
what do you want to improve for Clear MG from this set up?My set up. Cannot decide on DAC/AMP.
maybe iFi Diablo?
Get a DAC/AMP. i did have the DIABLO which sounds massively better then the Apple donglewhat do you want to improve for Clear MG from this set up?
Does it matter that RME does not have balanced headphone output?Mg's sensitivity is exemplary, and if it makes sense, investment in a good DAC first would yield with much better results then with a "great" amp.
RME and Soekris all in one solutions come to my mind, but surely, there are others.
