SilverEars
- Sep 18, 2013
Whut? Denon d7200 wider? Not sure about that. HD800 is kinda oval stage, but yeah, it gives perception of large, but I think the imaging is more vivid with the Clear. HD800 imaging feels kinda flat. I find that the imaging of Utopia is even more vivid.Listening to the clears now and while the soundstage is not as wide as my Denon d7200s or sony z7m2, it definitely destroys both in depth and height. It just has a great 3D presentation.
It is a very realistic sounding headphone, it literally sounds like I'm listening to speakers.
My chain is PC > Jcat usb > audio-gd di20he > denafrips ares ii > audio-gd master19
I get a feeling that comparing 800 and Clear will make upper-mids to sound noticibly reduced with 800 if the ears are used to Clear. 800 needs time for upper-mids adjustment. Because I had times I come from another headphone and 800 sounds so muted in the upper-mids (not treble, there is a lot of that). Clear is easier to like first listen. 800 could be aquired taste due to it's response.
Clears also sound technically superior over the Stellia as well. It's open, so probably not the fairest comparison.
Yeah, the kink on the Clear is rediculous. They need to update it and get rid of the kink. There's design decision like the light color that gets stained easily I don't like.
