mattris
- Jul 23, 2014
Have you personally used the gear with the Clear? I tested the Clear on the Topping E30, and JDS Labs Atom amp prior to upgrading to the A18 & A90. The staging was non existent, whereas the HD800s on the same gear was wide and spacious. I have tested the Clear on a wide variety of gear. The fact that the Elear's are superior in soundstage is laughable, but the Clear is only a little bit higher in resolution.
The HD800s are within 1 to 2% of the resolution of the Utopia. They're equal in detail retrieval. The HD800s are noticeablely superior to the Clear overall. They're more resolving, higher resolution, huge stage, superior detail retrieval, more sub base ect, but they lack in slam and sound a tad thin. But this isn't an issue if you listen to classical music.
JFL, you actually bought into the snake oil of cables.
Have you personally used 'snake oil cables' with the Clear... or any headphone?
