Focal Clear headphones
post-13870032
Post #721 of 7,528
Jalo
post-13870040
Post #722 of 7,528
Wildcatsare1
This is very interesting as the frequency chart seems to show that the Clears has more bass than the Elear which is opposite to most report here.
That’s why I asked that question, from the charts in the Articles it appears the Clear’s have the superior bass.
post-13870042
Post #723 of 7,528
Ojisan
Texas
Texas
Focal Clear Measurements with comparison with Elear and Utopia - https://diyaudioheaven.wordpress.com/headphones/measurements/focal/clear/
Very nice. Wish I had known about your site before.
I forgot which track I was listening to but I did notice something ringing around 10kHz which I thought was a static noise (like "shhh"). It was actually cymbal or crash that went longer where it should have been quiet. So I did a test tone sequence and heard a dip around 4k and peak at 10k. The highs do (audibly) taper off quickly beyond 10k compared to HD800. Really enjoying the full body tonality of Clear so far. Maybe slightly fatiguing... not sure if it will mellow over time.
post-13870043
Post #724 of 7,528
iAudio365
Try the Campfire Andromeda with the original cable and then with the Reference 8 cable. The difference is not subtle.[/QUOT
Placebo is a hell of a drug :) or their could be something wrong with the cables.
Send your $1000 cables to James Randi who will pay you 1 million dollars if you can prove that expensive audio cables make a difference and you can have the audio set up of your dreams. Everyone that's tried has just embarrassed themselves from what I've heard, in fact not a single high end cable maker has even tried the challenge. I wonder why?
I believe there's also a professor at a well known university offering the same challenge and again no ones been able to do it.
Like I say they look wonderful and yes I will probably spring 100$ or so for a lighter and shorter cable for my utopias as that cable as everyone knows is just wrong although very well built, but the cables that come with the Clears are very very good there's just no need for them but people who drop the cash will tell themselves that.
Each to your own though
post-13870053
Post #725 of 7,528
Jalo
I don’t know about superior bass as the the chart cannot show that, but starting from100 Hz down to about 10 Hz, the chart clearly shows that the Clears has 1db to 5 dB more bass than the Elear. So all the impressions that say the Elear has more bass than the Clears are not consistent with what the chart shows. I am hoping that the chart is the correct one as I like the Clears to have more bass.
Reactions: Wildcatsare1
post-13870082
Post #726 of 7,528
ribosradagast
Happy Thanksgiving all!
Yeah that chart sure does show stronger bass than the Elear. If that's the case, I'm very interested.
Also, anyone know of any deals on these this holiday season? The headphones, not the chord
post-13870088
Post #727 of 7,528
donlin
Chicago
Chicago
The stock cable is very good. It sounds noticeably better than my Nordost Blue Heaven which was a nice improvement on other phones.
post-13870133
Post #728 of 7,528
Ekul61
Just will have to take a listen. hopefully much greater bass than the 800S. The low bass clinical sound can get boring.
post-13870147
Post #729 of 7,528
SHAMuuu
Not sure if any of this information was mentioned prior, but i could not find certain information and was digging for it. In Utopia the surround material was stated to be 70 microns thick, and i couldn't tell if the dome material Beryllium was 70 microns as well in this article it didn't say http://country.focal.com/get.php/media/homes/casques/Whitepaper_Headphones_PC1281.pdf . But in this video he says it is only 20 microns thick :xf_eek: . It was something i looked for and couldn't find. Maybe my searching skills are bad. Also he speaks on the magnet differences of Elear having one neodymium ring vs 6 segments on the Utopia, which is heavier overall the magnet structure than Elear which results in higher magnetic flux. This is reason for carbon fiber use in headband vs aluminum in elear. Wonder what is on Clear? Also the excursion of 10% (4.5mm excursion on 40mm) of total diameter of loudspeaker diameter, which he says is nearly impossible on loudspeakers in general. This was new to me, maybe not for all. If this has been stated, please ignore. The 135mg vs 150 mg loudspeaker mobile assembly weight differences have already been mentioned. I am looking for details on any differences with Clear if anyone has them. I am assuming the magnesium/aluminum material is also close to 20-30 microns, it was not directly stated, nor the magnetic flux rating. If anyone has numbers please share. If this video is repeat, please ignore :)
basically all after the 5 min mark... if anyone is interested in the info i mentioned.
:D
post-13870216
Post #730 of 7,528
paul30d
Australia
Australia
I was wondering the same thing. The graphs seem to show that:
  • The utopia and elear have exactly the same bass response (10-100Hz). But the basic selling point of the elear (other than price) has always been that it has more bass than the utopia. Maybe the elear just sounds like it has more bass, due to the reduced treble?
  • The clear appears to have more bass than either the utopia or the elear.
I guess you cannot read too much intp these graphs. The treble measurements seem consistent with people's listening impressions though.
Reactions: BunnyNamedCraig
post-13870256
Post #731 of 7,528
To my ears, the Focal Clear definitely does not have more relative bass than the Focal Elear.
As for measurements, following are our measurements of the Focal Clear (from our audio measurement lab at the office). The first are the three frequency response measurements (Elear, Clear, Utopia) overlayed as-is (one view uncompensated, the other with KEMAR diffuse field correction applied):
Following is a different view of the above measurements. For these measurements, I picked an alignment point (5.612 kHz) to give an alternate view, which I hope (in combination with the ones above) gives you a better understanding of the relative measured differences in overall frequency response between the three models:
Frequency Response RAW - Normalize 5.612 kHz - Focal Clear - Elear - Utopia.jpg
Frequency Response DF - Normalize 5.612 kHz - Focal Clear - Elear - Utopia.jpg
The audio measurements in this post were made using:
I don't have any information about the measurement system used to make the measurements you were discussing. (I'll look later.) Based on what I'm seeing (when comparing the graphs), we're likely using different setups. Following are a couple of links to discussions about different measurement setups and different results:
post-13870633
Post #732 of 7,528
paul30d
Australia
Australia
Those graphs are much more consistent with the various listening impressions and descriptions that are around for the Clear.
post-13871128
Post #733 of 7,528
Wildcatsare1
The Clears are in the House, other’s have posted about their good looks, and they were spot on! It makes the HD800 look like a tinker toy. Letting them warm up to room temp, then I’ll start burning them in. Packaging is very good, not LCD3 Wooden Case good, but again superior to Sennheiser.
Reactions: Matro5
post-13871306
Post #734 of 7,528
donlin
Chicago
Chicago
Had mine for a couple weeks now and just about ready to pack them up for return. They definitely have some good qualities but just too fatiguing for me. I find my ears in pain too often.
post-13871503
Post #735 of 7,528
Ekul61
Just returned the 800S , audeze 3 will be here mon. Never ending journey.. If they dont work im buyng some $500 cans and be done for awhile.
Users Who Are Viewing This Thread (Users: 4, Guests: 7)
