considering I like the Mojo sound signature? or other recommendations?
The Meier Audio Jazz ff is a neutral (but not dull) sounding amp and I think you'll like it, but the gain may be be too much for the Clear if you can't reduce the sound level from your DAC - I believe the Meier Audio Classic has less gain but I haven't heard it. The Arcam rHead is a good choice with a sound that's slightly darker than the Jazz ff and Mojo. (Edit: my ranking for your use case is 1- V200, 2- rHead, 3- Jazz ff)
I haven't heard the Lyr 3 or Jotunheim, but most of what I've read seems to indicate that the Lyr 3 is the better amp because it is more resolving/detailed. With all that said, I believe your EL DAC will have more effect on the sound than the amps I mentioned. Good luck with whatever you decide to buy!
