Good grief... let’s use science for power required, and our personal preferences for synergy.
Just use a headphone power calculator to figure out what the headphone requires for power instead of just guessing, or perpetuating power myths.
This one is easy to use:
http://www.digizoid.com/headphones-power.html
Just input the resistance and sensitivity. For the HEK v2 (35 Ohm, 90dB SPL/mW sensitivity@1kHz) the results are the following for various SPL peaks:
Most gear, including most DAPs, can produce enough power to be fairly loud. Head Fi has this bizarre habit of equating max power output to quality of sound. Don’t do that. There’s so much more to synergy with headphones and low distortion / quality sources than just max power. Of course, if the gear is Current limited it’s going to not sound as good, but according to the math 52.78mA of Current isn’t much at 110dB SPL peaks. 1.9Vrms for 110dB is certainly doable for most DAPs as well. The HEK v2 is planar dynamic which means it is a purely resistive load and the impedance curve shouldn’t vary across the frequency spectrum. Sometimes I wonder how loud people listen to come to these ‘not enough power’ comments.
Now, the Focal Clear has a resistance that varies over the frequency spectrum and will need a different approach to calculate the power required. Using the PDF measurements from Innerfidelity we can see the Clear’s impedance maxes out around 325 Ohms at 50-60Hz. Knowing this I would input 325 Ohms in to the calculator along with the 104dB SPL/mW@1kHz sensitivity to see what I need to drive the Clear enough in the 50-60 Hz range.
This is the Clear’s requirements for the highest part of the impedance curve, based on the math:
Even accounting for the variance in the impedance curve anyone can clearly (pun intended) see that it is far easier to drive the Clear than the HEK v2. The sensitivity is the major factor regarding the power requirements and the impedance affects the ratio of Voltage:Current. Even when changing the impedance to the advertised 55 Ohm@1kHz and using the same sensitivity the power output requirement is approximately the same, but the lower impedance requires less Voltage and more Current. This is the math:
No doubt the HEK v2 requires more power, but it isn’t as much as many think to potentially cause hearing damage quickly. The main point is that power output is one of the least important specs when it comes to quality gear once there is enough with a little bit of headroom for distortion considerations. More important to finding quality gear is clean power supply rails, total distortion levels, slew rate, tuning, synergy, etc.. The rub is that a lot of quality gear will also have high power output so it’s easy to mistake quality sound with higher max power output. Also, headphones like the HE-6 and Susvara are very insensitive and they DO require a lot of juice, but they are the exception to the majority of headphones out there.
