ubs28
- Aug 2, 2013
No distortion here with Blade Runner 2049 first track.
Thanks - which amp are you using
Much, much better? There shouldn't be any crackling noise whatsoever. Don't you think? I had both the Utopia/Clear out on loan and ever experienced this issue with either. I've never experienced this on any headphone I've borrowed/owned.I just got a replacement set of Clears (I am using the Clear Professional) and the crackling issue is much, much better.
My sorta ballpark comparison would be that the Elear is an upgrade to the Philips Fidelio X2 sound. An audiophile basshead's tuning, with some non-fatiguing sweetness up top. The Elex and Clear are closer to refined version of the Sennheiser HD650. Neutral warm without the roll-off at either end of the frequency graph. I have no first-hand experience with either the Clear or Elex, but I did EQ my Elear to sound like the Elex based on the FR graph and it reminded me of the HD6XX (also, their graphs are awfully similar).
The Utopia seems more like it's for bass-thin, analytical fans? This is the price range I have the least amount of time with. Also, I really find analytical tunings to be very fatiguing, so I avoid.
Certainly a debatable thought. I’m not sure many that have listened to both would agree with you. Ask Tyll from Inner Fidelity.The Utopia (with high-end cables) has more bass slam and has a better defined bass than the Clear. So not sure what you mean that the Utopia is for bass-thin, analytical fans?
What are you using for a headphone cable?The Utopia (with high-end cables) has more bass slam and has a better defined bass than the Clear. So not sure what you mean that the Utopia is for bass-thin, analytical fans?
Sounds like u have a nice set up. But with a balanced cable and a Violectric 280. The Clear bass is more enjoyable and real to life than the 800S and Utopias.Well, Tyll is probably running the stock cable and also a different setup than mine.
It’s simply down to speed and resolution of the driver which allows the Utopia to have more slam as the bass of Clear sounds more like a “blob” and “softer” to say it like that.
