Mimouille
Sensaphonics full sleeves and Custom Art custom tips. The Custom Art are better quality silicone and more convenient. Haven't compared sound yet.
Great impressions. The KSE1500, which I own, require quite some time. First of all it is not so easy to find the right source. Of course you can use it as USB DAC and it works fine, but you won't take full advantage of the potential. The WM1Z just doesn't work. I couldn't find a volume / gain / pad combo that sounded right. So far my best source is the Lotoo Paw Gold, out of the light out you have a resolution champion. It isn't very kind to badly recorded music (60% of what I own).
I will try when the kids leave me sure. But the KSE1500 treble is great as it is. You should find happiness with tips.If I may ask you a favour, could you try this out on the LPG, to see if it helps tame the treble on the 1500?
1) On your LPG, open any one of the five User EQ settings
2) Choose Filter 04 and then set: FO = 9000Hz; Gain = -5dB; Type = BPF; Q = 1
3) Make sure all the other filters have a Gain = 0
I know you are not an EQ person. I am actually considering getting a KSE1200 in the near future and, am interested to know if that helps to smooth the treble down.
I hope you get them back switly, without any delays!
BTW, undercured shells can sometimes happen with very dark or opaque acrylic colours, since it takes longer for UV light to penetrate these.
Are your shells a very dark or opaque colour, David?
The amount of filth on this thread..Yeah, that's what she said...
Mim', when you say full sleeves, I'm not familiar with that - do these have a way to insert an IEM inside them (by the user), or are they manufactured around a customer-supplied IEM, only removable if the sleeve is destroyed?
...or something else?
You need to try the linum bax, it's super thin and skin colored.I went through that bling phase with CIEM designs. My quest is to find the right color and transparency to my skin color now. Even if it tramples on the hearing aid look side.
With the 2-wire, it's pretty seamless and stealth. I need to zoom in a few times in the mirror to notice that they are there. I'm going to try to have the transparency reduced 25-50% on my next set...
My problem now is how to make the cable not draw attention...
Mim posted a couple of pics on the last page or so. Full sleeve basically makes it look like a full ciem, custom art "just" do the tips that slide on the nozzle.
Question for Mim whilst I'm here. How well do the CA tips stay on the nozzle? That was always one of my main fears, that it would come off the nozzle when removing the iem from your ear!
Of course it's all a matter of personal preference, but when I tested westone's UM56 custom tips, those didn't work for me too well. The custom tips go on top of the nozzle and will spin around it. Custom eartips have to be inserted into earcanal just like CIEM, the corkscrew style, they don't go in straight like a regular silicone tip. And while I was putting those in, the shell was spinning around the nozzle. Full sleeve goes over the body (partially) of the shell and should "stick" to it better as you putting them in your ears.
