Also, does anyone know why Spiral Ear is so particular about closed-mouth ear impressions? What happens if I sent in one done open-mouth which is the norm?
flinkenick's 17 Flagship IEM Shootout Thread (and general high-end portable audio discussion)
Tulku1967
- Jan 6, 2016
5 pieces of thin silicone tubes can collapse if you close your mouth while listening to musicAlso, does anyone know why Spiral Ear is so particular about closed-mouth ear impressions? What happens if I sent in one done open-mouth which is the norm?
Wonder what happens if I sing along5 pieces of thin silicone tubes can collapse if you close your mouth while listening to music
Tulku1967
- Jan 6, 2016
If you send a closed mouth mold, there is probably nothing extra ...Wonder what happens if I sing along
If you open your mouth, then maybee you will be slightly separated from the inner mold when you close it and it will come in contact ... but silicone always has better isolation properties than acrylic, so you do not have to keep it from leaks.
Silicone elastic material, greater "isolation tolerance" in such cases.
I have a silicone custom tip on my U18 nozzle and get better isolation than my other full acrylic CIEM
I initially thought so too, as it must have been a huge investment, but then a while back he was looking to buy his dad CIEMs. His dad had apparently been eyeing Nic's mountain of (C)IEMs but he couldn't part with any because they were his "babies".I always thought that Nic would have like, a massive sale to get rid of his not-so-favourite CIEMs once he's done, except the review samples. Realistically, I don't like to do too many shootouts or a/bs bcos I often end up selling the loser.
I had to part with the majority of mine to continue to write reviews or fund my habit, it has been quite costly. Obviously, if you given review samples you can't part with those but I have never written for another blog or website, only for myself and Head-Fi.
eldss
- Feb 5, 2015
What tips do you use?
proedros
@ezekiel77 i see you selling some quite good iems , may i ask which ones are you keeping ?
btw whoever said how Zeus cunningly day by day makes you get addicted to them was right
great ciem , NT6 has been gathering dust when i am at home (i take NT6 when outside)
Tulku1967
- Jan 6, 2016
dongster
- Aug 23, 2016
would be interesting to see a FR comparison
It's a lot better sound than the stock tip.
I'll write about the tips effect on sound, but I think I figured why I heard other sound signature than Nic in her test.
this tip changes so many parameters:
1. tube length
2. diameter
3. angle
PinkyPowers
Reviewer: The Headphone List
1. tube length
2. diameter
3. angle
The only way you'd get anything close to an accurate reading is if the measuring apparatus was also custom molded to fit those tips perfectly.
dongster
- Aug 23, 2016
i think as long as the putty doesn't squish the tip tube diameter its should give reasonable resultsThe only way you'd get anything close to an accurate reading is if the measuring apparatus was also custom molded to fit those tips perfectly.
eldss
- Feb 5, 2015
Are those tips sold by AAW or did you find someone else that makes them? I've been looking for optionswould be interesting to see a FR comparison
1. tube length
2. diameter
3. angle
dongster
- Aug 23, 2016
replied to the wrong comment bro,Are those tips sold by AAW or did you find someone else that makes them? I've been looking for options
might wanna ping the op again
@Tulku1967
btw i know snugs makes these as well
and many hearing aid shops for around a 100 Euros
PinkyPowers
Not if the point is to compare them to normal tips. The sonic benefits of custom is due to the God Seal more than anything else.
Total: 16 (members: 0, guests: 16)
