I think it is important here to mention that objectivity is not the goal of science, it is merely part of its methodology. The goal of science is to understand things, "the pleasure of finding things out", and sometimes it is not possible to do that in an abstract (objective) form. Do we then stop and not look at it? Of course not. If we would do that, progress would grind to a halt.Dongster your argument is very valid. Based on your posts, it appears you either have an academic or a research background or you have learnt things out of your own interest. Either ways, you might understand that, just because a methodology to objectively quantify an entity or a behavior does not exist, the entity does not automatically qualify as an entity of non-objective nature. In such a circumstance one needs to work towards finding a method/procedure to objectively measure it.
Currently, there are no methodologies to objectively measure the soundstage. And in order to find ways to measure soundstages, we need to define what soundstage is. It is a simple term used by audiophiles to describe an IEM’s ability to locate instruments at a distance away from the center of your head. It is made up of two qualities:
1. IEM’s ability to place all sound (regardless of the wavelength or continuity) outside your head
2. IEM’s ability to recreate the distance and directional information in the recording
So by your extreme example, where you have a vocal track recorded in an anechoic isolated chamber, it would be free of any directional or distance information. But if an IEM portrays the vocal slightly outside your head, we need to start determining if it is placing only the vocal (continuous waveform) outside your head or, if it is able to place even a monotone outside the head. Because, science is not just about proving something is of objective nature, but it is also about proving that something is NOT of objective nature. And in case you determine that the IEM places all sounds outside your head, then you could start investigating what causes this particular IEM to place all tones outside your head. But to do all this you need a point of reference and a standard/unit.
Now your argument about there are just 2 functions when it comes to IEMs; Amplitude and Time, it ties back to my argument above. Yes, terms like soundstage, clarity and tone are just jargons used by us audiophiles for easy everyday communication. But there are underlying entities that govern or contribute to these jargons. Just because we have not figured out a way to objectively quantify these entities, it is not right to say that these are subjective aspects.
The problem I see, and I see it in these types of audiophile discussions as well, is that people get too obsessed by objectivity and by trying to force it, end up with something that has nothing much to do with the original subject of enquiry. It turns into an abstract exercise that has little to do with anything other than "trying to be objective".
