Do you know if it can drive a very difficult headphone like the Susvara? I was told my Hugo 2 would not be powerful enough for that. I would like to try one out some day, but with no CanJam, I would need to drive it myself. Tks.
You can absolutely not, in any shape or form, drive a Susvara with a Hugo 2. The ifi micro BL is 3 times as powerful as a Hugo and it still can’t even scratch the surface
Wow! They are not kidding when they say an amp is needed. Can you simply use a 2-channel stereo amp, or is anything in the middle needed? Just curious should I ever want to audition it. Tks.
You can use a 2 channel stereo amp but you’d need an adapter to be able to connect the Susvara to the speaker taps in the back
realistically though, a powerful enough HP amplifier with 13/14W per channel should be able to get the job done more than adequately. Nothing portable is currently able to do that though :S
If you read over Susvara’s thread, one of the recommended amps is Pass Labs XA25, which has 25W of output and it’s a speaker amp. Or if you want to use headphone amp, Hifiman has one that’s purposely built for Susvara, the EF1000. It has 20W of output, but I believe you have to buy it as a bundle with Susvara and the bundle retails for $18,000 though.
Yes but the guys are going a little overboard with the supposed power requirements in that thread imho.. I just enjoyed the Susvara with the XI Audio Formula S, which was designed for the Abyss 1266. The output of this amp is 6W @ 16 ohms. To my ears, it sounds fantastic with the Susvara, with lots of headroom.
Thanks for all the feedback. I had asked as I do have an old Forte Stereo amp I do not use. I would have to dig it out though. I may or may not increase the power of my desktop set up. I really like just using my N8 on the couch though which is why I was asking about Daps. At the moment not an issue as I do bnot have a Susvara or Abyss, but I would like to audition at some point. My 2 channel system really serves as my reference and regular system, but with my family home, having the ability to listen at normal levels whenever I want is a plus.
Sounds like I need at least 7 watts or so. Good to know. Thanks all and hopefully I will remember this advice!
Maybe... I have the Formula S with the Powerman power supply, and I have read that this probably contributes to its great performance at 'relatively' modest output compared to the speaker amps etc..
Ah yes, I’ve read wonders that the Powerman can do to the Formula S. I agree that a very good power supply is essential to get the cleanest and best possible sound. Will keep this in mind
