So my problem is for example, Dream XLS, there have been a couple of reviews/first looks and everyone has appeared to gloss over the horrible fit issues. I love the sound but to try to maintain the sound for an extended period is darn near impossible. The fit has only slightly, if at all, improved. I know Daniel hasn't completed a final review so I am sure it will be mentioned.
The sound quality is very good, with quality bass transients. The fit is a real issue. This is the sort of useful information consumers need, not wordsmithing.
Yep, coming soon. I've been juggling lots of different reviews lately to keep myself from getting bored writing about one product. The side-effect to that is they're all collectively taking longer to finish. Regardless, the XLS one is the closest to being finished, and I will talk about its fit in it as well. To spoil it somewhat, I do consider it the weakest aspect of the XLS. While I had much greater luck maintaining the fit than you did - then again, I did listen to it while mostly stationary, and never took it out and about - getting a good fit itself proved quite the ordeal. I often found myself pressing the in-ear's metal chassis against my skin to get the nozzle to lock in, which I wasn't too fond of. Again, it'll be in the review, which isn't far off now.
