Gabriel Sontag
Why is there so much sibilance
For me the peaks are at around 6 and 10 khz.Why is there so much sibilance
I actually kinda got used to it.
Massdrop Plus Universal IEMs
Nah it's just different. It's up to you whether it's better or not.Are the Massdrop Plus Universal IEMs considered better and an upgrade over the FLC8S??
I didn't think that happened around hereSome people felt it was overhyped.
IMHO, yes. In fact, I'd rate it higher than the IE800.In Crinacle's iem ranking list he's got these at the same level as the SE846, ie800, and Dunu 3001 (amongst others). Is it really that good?
Hi, firends. Hasn't found a separate subject about FLC 8D, and I have decided to write the reduced translation of my review here.
And where is it the integral non translated version? Italian, I suppose...
Thanks for the wonderful review!Hi, firends. Hasn't found a separate subject about FLC 8D, and I have decided to write the reduced translation of my review here.
FLC 8D: four sides of a delightful sound
Welcome all judges of good portable audio. Recently we have got acquainted with remarkable FLC 8N earphones which blow the mind even 36 options of correction of a sound at the expense of the whole lot of filters, and time for their younger brother has come now. Model 8D has no such abundance of variations of fine tuning, but it is that case when a little – doesn't mean badly. Running forward, I will tell that ears have left behind the kindest impression. But about everything one after another.
Specifications
Drivers: 8.6mm Dynamic Driver+Dual Balanced Armature Drivers
Frequency Response: 20Hz~20KHz
Sensitivity: 107dB/mW @1KHz
Impedance: 11 Ω
Connector: 0.78mm Two-Pin
Plug: 2.5mm Balanced or 3.5mm Gold-plated L-Plug
Appearance, set and ergonomics
Earphones have arrived in same, as well as at model 8N, a nice box of olive color.
On the forward squeezed-out silvery logo of a brand is placed. Under a cover it is found two cards, they looks like a business cards: warranty card and instruction. Further we find earphones and the round jar similar to that in a bright yellow insert that was last time. This jar heavier and isn't closed, but screwed up on a carving.
In this "washer" we find all the rest: 8 couples of different tips, a metal flask charm in which filters, the device for cleaning sound tubes, the adapter 6,3/3,5 of mm and my favourite clothespeg for fastening of a cable to clothes are stored.
The shell of 8D metal, blue color, exactly in tone to a flask charm. Earphones are easy, convenient and ergonomic, landing comfortable. Assembly of claims doesn't cause, a hint on side plays or gaps.
On an external half of the case is small ravines of a brand. On internal I have accommodated sound waters in which the filter is screwed in, and it is slightly higher than three tiny openings, forming a triangle. Unlike model 8N ports for the subbass and bass filter are absent.
From above cases there is a socket for connection of a cable.
The cable of the 4th wire, replaceable, blue color, is in harmony with earphones. He is elastic, it is made of copper of high cleaning 7N, purity of the conductor of 99,99998%, looks completely reliable. Connectors 2pin with deepening in socet, Jack L-shaped with gilding. Upon purchase as well as in a case with the senior version, it is possible to choose the plug of 3,5 mm usual (as I have made) or 2,5 mm balance.
As you can see, the set pleases with all necessary. And what isn't present here, that also optionally isn't provided in this model.
Filters
Here we also find the main differences from the senior earphones. Fine tuning of FLC 8D is possible only 4 types of filters:
Gold - vocal / mid focused
Blue - force low-frequency range
Green - raise high frequencies
Graphite (according to gunmetal producer) - neutral
If to compare with 8N, then set looks frankly modest, but, believe, in a case with his FLC 8D it has appeared quite enough. Besides it is much more difficult to lose these filters, and to install them simply, even the tweezers aren't necessary.
And now we pass to a sound.
Sound
Listening was carried out on MyST DAC 1866OCU V.2, Lotoo paw Gold, iBasso DX200 (AMP7), iFI xDSD, and iFI micro iDSD Black Lable.
With all devices FLC 8D played is wonderfully well. Before use they have been burn-in about 45-50 hours that has positively influenced their sounding.
Despite similar specifications, sounding 8N and 8D some differs. The younger model draws more blank and spacious picture, and senior in turn builds space in depth better. I can assume that in them different drivers though it is only a guess are used.
In the whole FLC 8D sound more widely, openly and analitichno at similar combinations of mid/high filters.
At the installation of the gunmetal filter the manner of sounding of younger model turns out more spacious, with smooth, very detailed middle, net collected high frequencies of which quantitatively it is more, than in 8N, but on quality of working off, in my opinion, they it is better. Low-frequency range equal and more monotonous. There is no such timber variety, speed and accuracy of blow in a lower case as in a case with 8N, but there is a sustained and velvet bass that gives identity and charm.
The high-frequency register as I have already told, is fulfilled more precisely, more purely and more lingeringly. Quantitatively it is more of him, and personally I would reduce this speed. What without problems also managed to be made. I will tell about it below.
Now we insert the gold filter and we receive almost ideal picture. If at the senior model I have preferred the graphite (gunmetal) filter, then here my choice - gold!
Low-frequency range quantitatively remains practically same as in a case with the graphite filter, but at the same time it becomes more built and adds "bodies" around the lower middle.
Mid-frequency range accurately adds emotions, remaining smooth, open and extremely detailed, beautifully drawing in detail each detail of composition.
High-frequency range has restrained the heat, has ceased "to spark" and be allocated excessively against the background of the middle. What is necessary!
This sounding reminds a combination graphite (gunmetal), gray, graphite (gunmetal) at the FLC 8N model, but with slightly impoverished low-frequency range.
At installation of the blue filter high frequencies and a part of mid-frequency range are accurately extinguished at the expense of what Low-frequency begin to dominate a few.
And the green filter is intended for fans of sparkling, net and air high frequencies. Too in own way the interesting control which quite have the right for life.
My choice has surely fallen on "gold"!
For example
Paul McCartney & Michael Jackson "Say say say"
The composition sounds smoothly, purely and very musically.
The blow is exact, dense, quantitatively there isn't a lot of it, it goes approximately level with the middle. The bass fast and collected that still would be advisable to it, so is weight and a tembralny variety, what in all beauty to us was shown 8N.
It isn't bad at all, but sounding nearly has a basis, "body", and for the rest everything accurately and definitely, won't carp.
Mids is smooth, expressive and detailed. Each tool, each sigh, contact of strings, is transferred truly and beautifully, with a due share of an expression. There are no irritating factors which can excite hearing shouts and sharp splashes, everything is sensible, accents are placed competently, it is possible to hear this case long and with pleasure
Voice parts are perfectly transferred, in ears and sweet-voiced roulades of Mr. Paul and Michael Jackson flow.
«…You never ever worry
And you never shed a tear
You're saying that my love ain't real
Just look at my face these tears ain't drying…»
High frequencies are reasonably maleficiated, them, in my opinion, in the considered control there is so much how many it is necessary. And to their quality of working off it is difficult to show something. All grandly, culturally.
Conclusion
FLC 8D - uncommon IEM. Despite much smaller number of filters, they as well as the senior model, are capable to satisfy inquiries of the most exacting fans of a sound.
Besides a set, quality of assembly, design and ergonomics - everything, as well as in a case with 8N, at height!
And here the price on 8D is much lower. Generally, if you need a serious sound which also can be arranged on the taste, then these earphones undoubtedly are worthy to appear on your head.
Pluses
Sound with 4 options of fine tuning, a set, quality of assembly, design, ergonomics, the price.
Minuses
No.
