Flcforrestwei
Member of the Trade: FLC Technology
- Nov 22, 2015
Hi Guys, please discuss FLC8n in the other thread: https://www.head-fi.org/threads/flc-technology-new-flc-8n-impressions-thread.885016/
After getting my flc8s back from repairs i am enjoying these a lot. These need a bassy source to shine according to my findings. Give these puppies a warm source with good recordings and these will sing.
So far my favorite comination is grey grey gold. My source le max x900 is mid bass heavy so i don't need red plugs. Using tidal hifi and the output is exeeding my expectations.
Just wanted to provide a nice shout out to LMUE (Lend Me Ur Ears) in Singapore. They are the key stocking distributor for FLC, and that is where I go when I lose little pieces for my FLC8S. I also bought a bunch of FLC IEMs from them, and some upgraded balanced cables also.
Anyway, my cables started coming loose on my FLC8S pair, and they sent me a replacement set under warranty even before they received my defective parts. They replaced both the cables and the IEMs themselves. Wow, what great service.
So at the moment I have two nice pairs of FLC IEMs, the 8S and 8D. Still on the fence about the 8N; as I am tempted to pick up the ibasso IT04 next just to have a different sound signature in the collection.
By the way, because of the tuning choices I like (fairly neutral) the 8S and 8D sound pretty similar to me.
Nice review..... I am facing that issue with vocals (the depth of the vocal is not felt) These pairs are amazing if not. Will changing the filters help vocal depth? Which configuration do you suggest?Just want to share some initial impressions on the 8N. My impressions are quite positive, and I want to be careful with my writing, as I don't want to start any hype given the fact that I don't have many other IEMs in the price range to compare. Just the Senn IE80S and the Simgot EN700Pro. And I prefer the 8N over both those IEMs.
First things first, the tuning system. I don't like the bass tuning filters as they are made of rubber-like material and seem quite delicate for continuous swaps. Not only they could easily wear out, but if you are not careful when swapping them, you could easily lose them given their diminutive size and bouncy nature. Especially, DON'T CHANGE THE BASS FILTERS IN A ROOM WITH CARPET FLOORING. The mid-high filters are fine as they are screwable type and are made of metal. But I guess these things are no news for people who already own the 8S.
So the sound... in its default config (Grey, Grey, Gold), 8N has a balanced, slightly warm and a slightly laid-back sound. This kind of tuning is right up my alley. But for someone preferring a neutral sound with detailed treble, the default config will come across smooth and quite laid-back. The placement of the presentation is neither forward nor backward and the stage is very spacious. Definitely wider than deep. So the lateral separation of instruments is very good while the layering is average. The note structure is quite neutral with the right amount of warmth and body. It doesn't display any strong characteristics that would swing the crowd in one direction or the other. Also it is not too neutral to a point it is boring either. A balanced sound that works with most genres and allows for prolonged listening without fatigue is what it is. Actually, for people preferring an exciting sound might find this config a touch boring.
With the DD in place for bass, you do get the nice natural decay and sub-bass rumble. Its just a touch north of neutral and is slightly warm. Actually the warmth really is from the slightly-toned-down treble than the bass itself. The mid-range is sufficiently bodied without favouring either instruments or vocals. While the mid-range is far from being soft, it lacks just a bit of dynamics. Also the upper-midrange is a bit on the smoother side. If you are someone who prefers the female vocals to soar and string instruments to have some bite, the default config may not rock your boat. While the treble is not excellently linear, it doesn't have any annoying peaks in an aim to artificially boost articulation and resolution. The treble extension is average and so is the resolution. Again, this is a $350 IEM, so you can't expect high-end level performance here.
While this IEM doesn't achieve any unparalleled feats, I really can't seem to find any negative aspect about the IEM in terms of the sound. I will test other filters and report back later. For now, I am very much satisfied.
Thanks. Do you recommend any other iem(under $500) that can give good vocal depth and is equally good with 8N? I was thinking of IT04 but looks like it has the same issue.Thank you. Unfortunately, the mids on the 8N is a bit relaxed. With the Grey+Clear+Gold filters combo, the IEM becomes mid-centric to an extent. But it still wouldn’t give you the deep vocals you are hoping for.
I have the 8s and I can recommend the Toneking T66s for an upgrade on mid and high refinement to the 8s.Thanks. Do you recommend any other iem(under $500) that can give good vocal depth and is equally good with 8N? I was thinking of IT04 but looks like it has the same issue.
