dlayman
- Oct 23, 2015
Loving the FLC8S after daily use over the last few days since getting them. The Crystal Silver cable makes a nice difference as far as microphonics (next to none) and memory wire (less stiff) goes. Still on the default grey/grey/gold setup and am fine with it. Will try red/grey/gold that everyone raves about over the weekend.
What I am struggling with is the ear tips themselves. Because of the wider iem nozzle (as compared to my W3 & W4) the tips tend to fit awkwardly in my ear canal, especially right ear. I tried Crystal Tips which are quite nice but not as "sticky" as Comply which causes the tips to eventually unseal/slip over time. I went back to the stock clear/white silicon tips and tried all sizes. Mediums are best but not as comfortable as Crystals and also tend to pull out of the canal over time. I have Spiral Dots on the way to try as well. What I would like is to find Comply and/or silicon double or triple flange sleeves that fit the wide-bore nozzle. The ones that I possess are for the Westones/Shure SE 535 and are narrow stem.
Point me in the right direction to suitable tips, FLC8mates.
In my experience when the tip slides out of the ear or you lose seal over time, the tip is too big and you need to go down a size. With a tip that is slightly too large, you can get a good seal at first, but as it continues to expand, it pushes itself out. That's why I use a small Crystal for my left ear and a medium for my right. My left canal is slightly narrower than my right. The medium would work well initially in both ears, but after an hour or so it would push itself loose in the left. Many people have differently sized ear canals. Try downsizing when you have this problem.
