LibiSC
- Nov 5, 2013
Don't know the KEF, but the FLC should play in another (= higher) league, especially in terms of mids and instrument separation. And of course for the sake of versatility:
ULF-Filters:
(ULF Filter I Grey I Gold)
LF-Filters:
(Grey I LF Filter I Gold)
MF-/HF-Filters:
(Grey I Grey I MF/HF Filter)
Excuse my ignorance where is the base line or 0 level in this kind of graphs?
LibiSC
- Nov 5, 2013
Actually, I think the silver / blue combo looks really good. Cable matches the eartips too.
In my eyes it's more like white than silver....
dlayman
- Oct 23, 2015
It can be anywhere really, but 1 khz would be a good frequency to use as a reference point here.
- Jan 30, 2011
It's relative so it doesn't matter. Take it as a flat line at -20 dB if it suits (ie the 1 kHz equilibrium point)
On the left side, at ~ -20/-18 dB should be the ground-line. Anyway, the graphs are mainly there to show the relative effect and difference of the filter groups.
dlayman
- Oct 23, 2015
Yeah, I guess it is more white than silver, I still think it looks good though. How are the microphonics with the cable? Is the cable stiff or pretty flexible?
LibiSC
- Nov 5, 2013
Microphonics are not a problem but i've been sitting while listening... the cable is longer than stock flc8 cable an it's stiff but not to the poing is annoying.. i think its made like that so it wont tangle
Jozurr
- Oct 25, 2009
Well I ended up buying the cable from effect audio (tf 10 one) cuase was cheaper. Forrest kindly offered me a replacement but I couldn't arrange the shipment with my courier. They look weird but now sound ok
Which version of the cable did you order and how do you like it? Microphonics? Any difference in the sound?
LibiSC
- Nov 5, 2013
Details of the order:
[Crystal] IEM Upgrade Cable by Effect Audio Connector UE TF10 Termination Type 1/8" Straight Color Silver | EA20101-UE TF10-1/8" Straight-A-Silver | 1 | US$49.90 |
Microphonics not a problem so far but im a my desk right now at work...Sound still awesome... Right now its all gray and usually I use grey grey red....I will have to switch it when i get home... But i think overall its the same sound...Also im using it with my work dac amp fiio e07k the one at home its bassier and more refined
Jozurr
- Oct 25, 2009
[tr] [/tr]
Connector
UE TF10
Termination Type
1/8" Straight
Color
Silver
EA20101-UE TF10-1/8" Straight-A-Silver 1 US$49.90
How much was shipping? Any idea where it ships from and which service they use? Cant seem to fins that information anywhere on their page.
LibiSC
- Nov 5, 2013
Company is in China... shipping was around 10 bucks to Perú ...there was another option of 20 or 40 bucks i dont recall
Standard International Shipping(10-15 Working Days)
- Jan 10, 2016
Company is in Singapore
LibiSC
- Nov 5, 2013
You are right... It shipped from China though
Whaleshark12
- Jan 6, 2014
I just found out that using dual flange tips does makes the bass go deeper.
Btw, @Flcforrestwei . Is there a filter inside the IEM's housing? I mean the acoustic filter. How much ohm rating is on it?
Paulus XII
Formerly known as FW214b
Thats correct.
