Code 24 is a tad less stiff than Code 23, but still a stiff cable in the vein of 23. It can almost stand up on its own, but not quiteCODE 23 thick gauge solid core surrounded by 12 multi-sized core bundles is stuff but very malleable / "shape-able". The issue for many is the earhooks and weight – if you turned your head frequently, it loosens your IEM seal eventually popping them out. Personally it's been a non-issue, I use Crystals which has slightly tacky ear tips and shape the ear wires in a way to reduce the cable from loosening my IEM seal.
From what I read, CODE 24 is thinner gauge which should improve ergonomics.
Glad to help and have a safe, healthy Happy New Year!
Fir Audio Thread - Discussion and Impressions
OhmsClaw
Lmao, et tu Sailor?Absolutely epic!
Just don't rock the boat...don't want to deep six your RN6 lol. Happy new year!
OhmsClaw
Well 23 is 99 off rn . You get an early tester?Code 24 is a tad less stiff than Code 23, but still a stiff cable in the vein of 23. It can almost stand up on its own, but not quite
@emdeevee‘s impressions
https://www.head-fi.org/threads/effect-audio-cables-thread.787717/post-17886866
And @fiascogarcia’s
https://www.head-fi.org/threads/effect-audio-cables-thread.787717/post-17894735
There’s a few others in the thread and in other channels.
apongsasin
- Aug 10, 2011
Stood up to feel the breeze actually . Same to you. Happy New Year with many new gear!Absolutely epic!
bogdan belonozhko
Sponsor: FiR Audio
Thank you all for making last year an amazing year for Fir Audio. The entire team wishes you all had a wonderful holiday season. Here’s to a new year and to more adventures together!
Stay updated on FIR Audio at their sponsor profile on Head-Fi.
likeafranfran
VxV v2 hidden message?
Doesn't appear to be all that well hiddenVxV v2 hidden message?
Daniel70928
Does anyone have a frequency response of any of the bellos audio models?
CP100s is a good match too IMO. Try this for 3.5mm connection. Didn't seem to degrade the sound too much. https://www.amazon.com/SHANLING-Balanced-3-5mm-4-4mm-Portable-Earphones/dp/B0BPRSPN4V
Unfortunately, this doesn't seem to be compatible with the 3.5mm outputs I've tried. But it's no big deal, since I already have the M0 Pro. I'll have to try the adaptor OhmsClaw posted instead.
I keep mine like this, bottom compartment. It's a tight fit but it's snug and safe.Do you have any issues with coiling some of the thicker cables/8W renditions into the travel cases? The Rn6 stock does leave a little room in the lid, but fills out the lower portion of the leather case pretty well without the IEM's clanging into each other/earhooks being smushed. (Are you running all of them between 4 & 5 feet?)
OhmsClaw
This is how I roll, so I gotta at least get em in the OG circle cases. (Green is dac and IC cables, lower tan is amp and power cables)
Another question about the VAC and VAC Pro. The 64Audio model has a suction force of 20 inHg according to the specifications. What about the FirAudio models? I can't find any information. @bogdan belonozhko could you answer this question?
Chunky Nan
So, I got my replacement KR5 in hand today after the serial number mishap with the last pair. Absolutely delighted with FiRs customer service.
But something worth noting, it seems to me there is pretty wide potential unit variation per pair.
My last set I wondered frequently if I was really experiencing the kinetic bass. It was strong bass dont get me wrong, but nothing really "different".
This new pair the kinetic bass hits different. Hard. You actually feel it in a different way. I guess like I expected (but never really got) out of my first set. It is immediately noticeable.
Just my experience but may be worth noting. Very happy with the replacement set.
