So basically all B3 needs only two BA to sound good with enough resolution?Sony and final are like brother
Final Audio Design Impressions and Discussion Thread
dakanao
- Jun 8, 2012
My E3000 have almost 200 hours of burn-in (let them play in for a week with a mp3 player I had laying around, connected to the charger so it doesn’t shut off)
I hope it’ll smooth out a tad
mochill
dependsSo basically all B3 needs only two BA to sound good with enough resolution?
mochill
Give us impression , also how loud did you burn inMy E3000 have almost 200 hours of burn-in (let them play in for a week with a mp3 player I had laying around, connected to the charger so it doesn’t shut off)
I hope it’ll smooth out a tad![]()
dakanao
- Jun 8, 2012
2 clicks above my normal listening volume.Give us impression , also how loud did you burn in
mochill
Which dap2 clicks above my normal listening volume.
dakanao
- Jun 8, 2012
A veeeeery old Tom-tec mp3 player I got in 2007. I didn’t listen to it in years, but I put the volume 2 clicks up from my normal listening volume.Which dap
Max volume on that mp3 player: 31 clicks
Normal listening volume of mine on that mp3 player: 17 clicks
Burn-in volume: 19 clicks
zenki
@mochill burn-in with different vol. make a difference?
At the end of the day, it’s not the number of drivers that is important (unlike the typical US brand thinking) but rather the tuning, the implementation. In the final audio range, other than the E5000, I would suggest trying the B1, B3 and of course the A8000. :)
Yea right now im eye ing on b3, a4000, and vr3000At the end of the day, it’s not the number of drivers that is important (unlike the typical US brand thinking) but rather the tuning, the implementation. In the final audio range, other than the E5000, I would suggest trying the B1, B3 and of course the A8000. :)
Add: so after some readings and thoughts, vr3000 carries the same driver as a3k and a4k. With said that a4k is a baby of a8k, thus the fr of a4k would follow a8k tuning. Meanwhile, vr3000 is based on VR, spatial cues tuning which likely a flatter fr like e500. With the price of vr3000, im probably will blind buy vr3000 soon when i get any chance of finding it. Vr3000 $80 same driver of a4k and tuned to be flat is going to be massive for me.
dakanao
- Jun 8, 2012
I think that will blast the earphones out, since 19 clicks is already unbearable for me (I listen to energetic music, so I listen to volumes slightly louder than the average audiophile)Try with full volume
- Nov 18, 2011
How do they pair with ZX507?
I haven't paired them yet - I just got the ZX507 and its a Christmas present (to myself!) so put away till the day.
Any chance of getting VR3000? VR series would focus on spatial cues and that new driver would probably be better resolution for sure than e500.Review A3000 and A4000 in Polish language https://forum.mp3store.pl/topic/196081-final-audio-a3000-i-a4000-porównanie/
mochill
Don't put it in your ears when burning inI think that will blast the earphones out, since 19 clicks is already unbearable for me (I listen to energetic music, so I listen to volumes slightly louder than the average audiophile)
