mmoderni
- Apr 14, 2016
X7MKII FW1.1.0 firmware:
The following changes and improvements have beenmade to the FW1.1.0 compared to the FW1.0.9 on X7MKII:
1.Added FiiO Link control via WiFi (now for the Android app, you can choose to connect and control FiiO devices via WiFi or Bluetooth; for the iOS app, it's only available via WiFi);
2.Fixed issue where the player would stop playing in Line out/Coaxial out mode if the screen is off;
3.Fixed issue where the Idle poweroff timer would still take effect when using USB Audio output;
4.Fixed issue where the change of the Theme setting would not be saved if using user-defined images;
5.Fixed issue where the audio was distorted when playing FLAC 192k tracks through DLNA;
6.Fixed issue where the 'Skip through folders' function might work abnormally when 'Resume play' was enabled;
7.Improved issue where some characters of the track info were displayed incorrectly;
8.Miscellaneous bug fixes.
