FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
post-14723450
Post #5,177 of 6,073
Paulo Abreu
Madeira Island, Portugal
Somebody can tell me the procedure to install the beta ?
Download the zip file as is and copy to the root of your X7 internal memory (X7 connected to PC with USB)
Start X7 on Android mode, go to app technical support and choose Firmware update, select the zip file and upgrade
This is by memory but should be enough for you to get there.
My 2 cents
post-14724310
Post #5,178 of 6,073
bootster
USA
USA
Mine says SD card unmounted. There is no option available to mount any of them. It looks like the internal memory/card is unmounted as well. I can access the SD cards through Windows, but not through the EX Explorer in the device itself. I cannot view the root files in the device, but I can through the Windows interface. I can't understand why there is no way to view the 2 external SD cards or the internal memory, therefore I'm not able to run any programs through the device, butt when I try to run the firmware update tool in windows, there is nothing there but the GUI that opens with all of the fields blank. When I try to run the OTA firmware on the device, it asks to select the internet or the internal files, but won't see anything because it cannot mount the internal memory or the 2 external cards. I give up.
post-14726210
Post #5,180 of 6,073
jprenaud78
France
France
My 2 cents
Thx i will reflash original m’y market disapeared
post-14726213
Post #5,181 of 6,073
jprenaud78
France
France
post-14731032
Post #5,182 of 6,073
Ultrainferno
Member of the Trade: Headfonia
Website
www.headfonia.com
post-14732174
Post #5,185 of 6,073
Judge584
I know! but since you have access to latest beta link maybe you can share them?
Or maybe @FiiO could add me to beta user
group.
post-14733879
Post #5,186 of 6,073
JaviAl
Madrid, SPAIN
Madrid, SPAIN
My new microSD cards for my FiiO X7 II:
post-14734206
Post #5,187 of 6,073
ClintonL
How do i bypass the battery when in usb dac mode? Just want it to run off usb power.
post-14735239
Post #5,188 of 6,073
tjl5709
S.E. Michigan
S.E. Michigan
Keep us posted on how well your x7 handles these, and to what level you load'em. That's a lot of data to manage...............
I picked up a couple 400's during one of the book stores christmas sale. They were like half off.
post-14735754
Post #5,189 of 6,073
peter1480
Edinburgh, Scotland
Edinburgh, Scotland
also how much of the 512 is available.
post-14735834
Post #5,190 of 6,073
Darren Cotter
With other cards I've used, it's just over 91% of the stated size that's available. With a 400GB card, you have 367GB free and with a 200GB you have 183GB available.
That would mean a 512GB card would give 466GB ish?
