FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Jun 6, 2018 at 5:23 AM Post #4,606 of 6,207
Take note that the Samsung T5 side is USB-C (not micro-USB). I'm searching about six month for a short OTG cable micro-USB to USB-C (that the micro-USB side is the host) but at today that cable not exist.
I have X7ii and a Samsung T5 as well.
If you're still looking for a solution, I had a short right angle micro USB to micro USB cable, and bought a tiny micro USB to USB C adapter to connect with the T5. This is the one I have http://www.ugreen.com.cn/product-958-en.html
Amazon Uk don't have them at the moment but this one looks identical.
https://www.amazon.co.uk/Adapter-An...76807&sr=1-5&keywords=usb+C+male+to+micro+usb
Jun 6, 2018 at 5:59 AM Post #4,607 of 6,207
Still looking for a best solution. Actually using a little USB OTG Cable to female USB Type-A and other little USB cable male USB Type A to Type C.
Jun 6, 2018 at 6:54 AM Post #4,608 of 6,207
@FiiO I actually emailed you a few days ago about the bug, but I did not get any answers....
I did what you told me (clear the data of FiiO Music app) and the problem still persists in all folders.
Dear friend,
We will PM you for more information.
Best regards
Jun 6, 2018 at 6:56 AM Post #4,609 of 6,207
Now i have the problem back again. The playlist appears on screen for half a second and disappears. However if I hit the little triangular back button at the bottom of the screen, the playlist reappears and stays there so i can choose what I want.
Needs fixing but at least there's a workaround for now.
Dear friend,
After pressing the back button, the issue disappear? Only happen the first time for a new playlist? We failed to reproduce now. But will report to the engineer about that and test more. Thanks for your kind feedback.
Best regards
Jun 6, 2018 at 7:00 AM Post #4,611 of 6,207
Here's mine - I keep the SSD stuck to the back of the case with blu-tack. It works perfectly, and the cable plus adapter cost about £7 in total.
A link for that little cable?
Jun 6, 2018 at 7:01 AM Post #4,612 of 6,207
Dear friend,
Best regards
No it happens every time I open any m3u8 playlist - I don't have any new ones. They all used to work OK before the last FW update.
Jun 6, 2018 at 7:13 AM Post #4,615 of 6,207
Dear friend,
Thank you for the kind feedback. We will try to test more and fix that in later update. Sorry for bringing inconvenince.
Best regards
Jun 6, 2018 at 4:58 PM Post #4,616 of 6,207
https://www.ebay.co.uk/itm/7cm-Right-Angle-to-Left-Angle-Micro-USB-Host-OTG-Cable-for-DAC-Digital-Amplifier/262471088485?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
It's not the same supplier I bought from, but pretty sure it will be identical. Mine works in both directions, so it doesn't matter which end you plug into the SSD.
I am quite surprised that an SSD Hard drive works on OTG on the Fiio. The response time is good ? and the access ? Do you made a media Library on the fiio ? thansk
Jun 6, 2018 at 8:06 PM Post #4,617 of 6,207
Dear @FiiO ,
I found a strange bug.
I will use X7 mkii.
I use a variable line out.
When using variable line output, the volume gain setting is apply to the line output level.
I recently purchased and use the AM0 module.
When I change the module of X7 mkii to AM0 and start the device, the high gain setting is not apply to the variable line output and it is fixed to the output level of the low gain setting.
When using the AM0 module, could you fix bug that the high gain setting is not apply to the variable line output level?
This bug does not occur in the AM3A module.
This bug occurs only when use the AM0 module.
Jun 7, 2018 at 3:07 AM Post #4,618 of 6,207
Yes. My 2 TB. SSD drive works very well, response time and access is good. In less than 30 minutes build the media library from more than 20.000 songs in Hi-Res (FLAC 44,1-384 Khz and DSD64, DSD128 and DSD256).
Jun 7, 2018 at 3:21 AM Post #4,619 of 6,207
Oh thanks for the info.
You must rebuild the media library at each connection ? For example, if you decide to not use the hard drive during few days and use only internal memory and sd cards.
And the battery draining ?? How about the autonomy??
Jun 7, 2018 at 6:23 AM Post #4,620 of 6,207
Dear @FiiO ,
I will use X7 mkii.
Dear friend,
We will test the issue you mentioned first and return back to you.
Best regards
