FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Discussion in 'Portable Source Gear' started by superuser1, Jul 6, 2017.
297 298 299 300 301 302 303 304 305 306
308 309 310 311 312 313 314 315 316 317
  1. AverageDude
    What is this for a stacking kit? Where did you get it?
  2. stilleh
    AverageDude likes this.
  3. LudoLVG
    Since the update, my fiio x7-2 takes much longer to power on and applications take some time to appear. Also when I pause the music on Neutronmp, it takes sometimes to restart and it indicates a red sd card....
    Little disappointed by this fact...
  4. russell finch
    It's ok. The first few hours after the update it behaved as i described, but the next day everything was fine.
    problem went away by itself
  5. JamesFiiO Contributor
    yes, it is already done, I can send you the .apk so you can update it in your X7MK2, pla pm me your email add so I can see if I can send you by email.
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  6. Cachicamo
    When will the update be released?
  7. Paulo Abreu
    Thanks! Can’t send you a PM. Privacy settings?
    Regards
  8. JaviAl
    Me too. The lists flash up on screen for about half a second and then disappear again.
  9. tjl5709
    Book store. Search this:
    SINJIMORU Elastic Band Holder
    Works perfect.
  10. Cherubian
    I bit of a off topic question here but anybody knows if FiiO's balanced cables RC-UE2B or RC-78B can be plugged into a standard CIEM recessed sockets (Custom Art in this case) socket? Thanks
  11. JaviAl
    Can’t send you a PM because of privacy settings.
  12. fredsvv
    I can't send an MP too. How can I send a message to you?
  13. JaviAl
  14. Vitor Valeri
    @FiiO I actually emailed you a few days ago about the bug, but I did not get any answers....
    I did what you told me (clear the data of FiiO Music app) and the problem still persists in all folders.
  15. russell finch
    Now i have the problem back again. The playlist appears on screen for half a second and disappears. However if I hit the little triangular back button at the bottom of the screen, the playlist reappears and stays there so i can choose what I want.
    Needs fixing but at least there's a workaround for now.
