FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Discussion in 'Portable Source Gear' started by superuser1, Jul 6, 2017.
229 230 231 232 233 234 235 236 237 238
240 241 242 243 244 245 246 247 248 249
  1. roy_allan79
    That did the trick!
    Thanks guys.
    Happy New Year indeed!
    howdy and LamerDeluxe (tm) like this.
  2. peter1480
    No problems with slot 2, two 400gb cards in each slot.
    LamerDeluxe (tm) likes this.
  3. Paulo Abreu
    Great news!
    After many many firmware updates since day 1 of FiiO X7 1st, now I always reset database, in android mode clean Fiiomusic and imageloader folders and re-scan all tracks again. This seems to kill most evilness
    roy_allan79 likes this.
  4. LamerDeluxe (tm)
    Thanks, that's is a very nice amount of space indeed. I wonder why it does work without problems for some, but not for others. What kind of cards are you using?
  5. peter1480
    Sandisak Ultra from Amazon UK
  6. LamerDeluxe (tm)
    Thanks, so two people using Sandisk cards succesfully. No idea if the kind of card matters, but what kind have you tried @brokengundam?
    EDIT: The card that was giving me trouble in slot 2, but not slot 1, is a Sandisk Ultra 32GB HC-I Class 10. Mind you, no card was in slot 1 when this card was causing trouble in slot 2.
  7. 13-7
    Did you check the integrity (i.e. audio checksum) of the files anyway?
    Corrupted files may play seemingly flawlessly on some devices and you may not even notice the corruption while listening.
  8. brokengundam
    I was using both slots. Both cards are Sandisk Ultra 256GB Class 10 XC-1. Neither of the cards were fully loaded. For me, slot 2 is trash. If the player goes to sleep, slot 2 "disconnects," deleting any songs from slot 2 I had put in queues or playlists, while slot 1 songs in same queues/playlists (poweramp) were unaffected. I like to make 6 -10 hour playlists/queues for work (I use the player as a background music player at the bar I work at), and it's rather frustrating to have spent an hour or two making lists only to have some or all the songs queued up disappear from the lists due to being located in the second slot. Once the second slot has been rescanned, it works fine, although slot 2 songs need to be readded to queues/playlists.. (at least until the player goes to sleep again).
  9. roy_allan79
    Unfortunately, I did not as I do not know how to do that, hehehe.
    I'm interested, how can I perform an integrity check?
    Thanks!
  10. 13-7
    Get foobar2000 and install this component here: http://www.foobar2000.org/components/view/foo_verifier
    Just right-click on the file(s) you want to check (either in playlist or library view) and go to Utilities -> Verify integrity - that's all.
  11. lantian
    Bought myself x7 mk2 a week ago, what fantastic sound it has with my JVC HAFW01. Fantastic player everything no matter the genre sounds fantastic. The Beatles hi res collection sounds better than the vinyls, great job Fiio.
  12. Darren Cotter
    What has the DAP manufacturer Hidizs got to do with Indigogo.com? You obviously think they have a connection, as you've posted this message on 18 threads.
  13. vrapan
    The AP200 was an Indiegogo campaign from Hidisz. Though given that quite a few people have received theirs he is kinda trolling.
  14. Jim Bobber
    Hi Fiio Support,
    Sorry it’s taken me a while, but I’ve just sent your support address an email with a playlist attached. I’m really hoping you can fix the issue where playlists on the Fiio Music app do not show in the order they were curated. This is a real pain as I create playlists for all the music I want on my player. To have everything then show in track order is a real pain. Please reach out to me for any other info you need. I’m sure this would be a real simple fix and I and others would appreciate it.
    Regards,
  15. FiiO
    Dear friend,
    If some third party APPs have their own decoding library and down sampling the songs, it is not affected by the X7MKII but the software itself.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official http://www.fiio.net/fiio http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
