FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
Sep 17, 2016 at 11:04 PM Post #14,326 of 18,020
My X7 has a compatibility issue with Mac in file transfer. Every time I copy files to X7's microSD card (SanDisk 128GB, ExFat, installed on X7) it always fails halfway and reports some kind of error. X7 then says the SD card was damaged but it resolved the issue after trying to prepare the SD card for a couple of times. Never had such an issue with Windows 7.
Hi,tomwoo
Could you please try to format your TF card to FAT32 (by X7 itself or some softwares in the computer) to see whether it helps?
Sep 17, 2016 at 11:50 PM Post #14,327 of 18,020
Hi,tomwoo
Well...I might try it with another TF card (when 200gb TF card becomes more affordable). It took me several hours to load this 128GB card with music...For now I will only use Windows for file transferring.
Sep 19, 2016 at 5:13 AM Post #14,330 of 18,020
@James
Is it possible to support DSD256 via a firmware upgrade? A lot of high music quality is selling in DSD256.
Thanks.
Sep 19, 2016 at 5:21 AM Post #14,331 of 18,020
  Question regarding 192/24 & 96/24 FLAC/ALAC files and downsampling, do I need to use the Fiio app to play such files or should Poweramp/Rocketplayer/Neutron etc... play them fine?
In Poweramp (without the unlock) they all sound distorted and slow and in unlocked Rocket player 192/24 just sounds awful.
With the recent fw updates, do I still need to use the Fiio app to play such files as indicated above. How does Rocket player sound now for 192/24. I have the x7 plus the am2
Thanks.
Hi, kgs51
Maybe the software you use is not compatible with the X7. Could you please have a try by yourself?
Sep 19, 2016 at 5:24 AM Post #14,332 of 18,020
  from where can i buy the ama2 online for international shipping as i like to have a more warmer sound sig than the am3 and am5
Hi, Sound Eq
Do you mean the AM2A module? We are so sorry that it is out of stock now.
Sep 19, 2016 at 11:51 AM Post #14,336 of 18,020
We have been waiting patiently since early July for an updated firmware that will address the many issues you have noted would be fixed. We have seen an impressive amount of hardware released and appreciate that hardware sales improve the bottom line. It must be time now that you release updated firmware for your flagship player.
Sep 19, 2016 at 6:06 PM Post #14,337 of 18,020
Hi all. I'm using sony f886+headstage arrow 4g with silver-gold lod cable. My question is x7 sounds (way)better than my f886+4g combo? I mostly listen rock/metal genres and currently using etymotic er4p.(want to buy psb m4u 4 or orivetti primacy)
