White Lotus
Reviewer for Stereo.net.au
- Mar 10, 2010
They aren't upgrading to MM. I don't even know if it's getting 5.1.1.
I'm not convinced!
I personally definitely think an upgrade to 5.1 is imminent.
I'm not convinced!
not sure if it has the right hardware for 5.1 (amount of RAM, etc)
i have trolling?? man, waiting for 6 month of new FW... where is trolling here? your X7 works correctly?
MacPilot can do that.
If you know how to use the terminal, this works as well, if you change NAMEOFDRIVE to the one that appears on the desktop when the card is mounted. Don't screw up this command though, as it deletes things.
Moto G 2014 only has 1GB of RAM, and runs Lollipop just fine:
Thank you!
Those commands should be kept somewhere easy to see for Fiio DAP users, or rather for any company's DAP users as the problem has been observed with many non apple products.
(I wonder if it would be complicated to make an app that erases those things automatically after an Android DAP was disconnected from a mac PC)
MacPilot might possibly have a setting for the system that prevents those files being written to FAT-formatted drives or somesuch.
OMG IT WORKED. How did I not know this before?
Sadly, Fiio seems to have stopped producing the AM1. I can´t see it anywhere on the Fiio website.
After I´ve lived with the AM2 for a while, I´ve returned to the AM1 because of it´s liveliness and sheer musicality. In comparison, I´ve found the sound of the AM2 too slow and boring. I guess, the AM2a will likely be a compromise between the naturalness and flow of the AM1 and the meaty sound of the AM2.
this should be added somewhere. i didn't know either.
Now to see how i can force my GNU/Linux machine to do that...
