- Mar 7, 2007
Happy new year folks!
Me thinks X7 + Foobar Mobile for Android...
Absolutely.![]()
Happy New Year!
...and, speaking of time marching-on, has anyone else noticed that iBasso are now listing the DX100 as a 'discontinued model'?
"Everything must change... nothing stays the same"![]()
Happy new year folks!![]()
Where am I?
Back on track, wondering if there will be any merit for me upgrading from the X5 to X7 (or any other DAP for that matter) if I am not interested in UI enhancements or otherwise, and ONLY use the digital out to feed the Hugo?!?
Man James must be really patient and open-minded opening the design discussion.
Half the people here seem to argue just for the sake of it, see only their end, complain endlessly, threaten not to buy as if they are someone to be reckoned with. Man if I did not respect James and want to know how this turns out I would have unsubbed a long time ago...this thread get so high on the annoyo-self-entitlo-meter.
maybe, X7 should supports DLNA.
There is a FooBar Plugin called foo_input_sacd
together with bubblguums Upnp Plugin FooBar can even
stream SACD isofiles as a 176kHz 24bit wave to my renderer
foo_upnp
foo_dsd_asio
foo_input_sacd
foo_input_dsdiff
foo_input_sacd_hq
It's a little bit of work plus more toys to carry for sure, we could put SACD ISO files on wireless 2TB hard drives. Install foobar2000 on ultra thin Windows 8.1 mini PC called Vensmile iPC002 with 7,000 mAh battery. Simply add some foobar2000 plugins as mentioned above.
Maybe we could stream DSD on-the-fly just like that without having to encapsulate them manually with FLAC containers, that should be called DoPE (DoP over Ethernet) so we just have to find out if AK240 were working with foobar2000 or otherwise.
If that were no go, we could try either MiniServer or JRiver Media Center on Vensmile iPC002 as well
http://www.head-fi.org/t/697166/the-astell-kern-ak240/5220#post_10862111
I have tested it with foobar2000 using "UPnP/DLNA Renderer, Media Server, Control Point" component (foo_upnp) on my laptop. It works, and I am able to stream my files from my foobar2000 playlists and music library via Wi-Fi, but the playback isn't gapless, and native DSD playback is not supported. I hardly ever listen to DSD anyway, but gapless playback is a must have IMO so I tend to just stay away from streaming.
Listening in USB DAC mode often has my preference whenever I am not out on the road. Staying at home with Wi-Fi enabled on the AK240 (USB not plugged in) will only deplete the battery even faster than it already does, whereas plugging in the USB cable will cause the battery to start being recharged even when a recharge is not yet required. (Frequent unnecessary battery recharges will cause unnecessary wear and tear on it, while the battery isn't easily replaceable...). So IMO it can be a good idea to transfer as much of the music you plan to listen to as possible via USB onto the AK240 or SD card, beforehand, then just try to avoid using Wi-Fi most of the time. Apart from the OTA (Over-The-Air) firmware update capability, the only times when I find Wi-Fi on the AK240 to be really useful is when I want to, without recharging the AK240's battery, transfer files from my laptop's external harddrives onto the AK240's internal storage.
FYI - these are the addition toys required
