FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
Jun 16, 2017 at 12:25 PM Post #17,342 of 18,020
Jun 16, 2017 at 12:35 PM Post #17,344 of 18,020
Hey bro!:crab:
"Those born under this sign wear their heart on their sleeve, which is just fine by them"
Man I have rubbed a lot of folks wrong. It's in my nature. So is the good stuff too.:palm_tree:
We are children of the moon :last_quarter_moon_with_face:
Nobody will ever accuse you of mincing your words, but I prefer people that are up front and honest about what they feel. Yes, I know I wear my heart on my sleeve and it sometimes bites me in the ass so I totally get that. Peace.
Jun 20, 2017 at 8:41 AM Post #17,346 of 18,020
Jun 20, 2017 at 9:18 AM Post #17,347 of 18,020
Jun 20, 2017 at 4:22 PM Post #17,348 of 18,020
My X7 is running FW 3.3 with a Sandisk 200GB card, Dignis leather case and AM3 Amp. I use it primarily for Tidal offline. Initially, it was awful - noisy, skipping and pausing. Turning off WiFi helped a little. Then I removed all 3rd party apps that use audio - Audible & Amazon Music- and that stopped the noise. Then, Tidal starts pausing randomly after playing for 30 minutes or so. I suspected heat (X7 gets really hot), so I removed the Dignis leather case and now it plays perfectly!!! Anybody know of a case with a builtin cold pack?
Jun 21, 2017 at 11:50 PM Post #17,351 of 18,020
Is Jude a moon child?
If not we take over.
Twister does the reviews,
You make the connects and I...
count monopoly money...and pretend it's real:atm::stuck_out_tongue_winking_eye:??
The kingdom is secure, now our reign shall begin.
Jun 25, 2017 at 1:42 AM Post #17,353 of 18,020
Will the X7 ever support AptX HD over Bluetooth?
Nevermind I found the answer earlier in the thread, but I too was mislead by Aptx.com saying that the X7 support AptX HD when I was planning on getting my DSR9BT. Til this day it still says it supports it.
Jun 25, 2017 at 5:59 PM Post #17,354 of 18,020
So I think I've softbricked my X7. I can't access the Launcher, I changed from the stock launcher, Launcher3 to Evie Launcher - renaming it Launcher3, rebooted and all I can access is the stock music player now.
I've reset the device using Volume up and Power and also tried inside the Android settings but it doesn't revert back to the stock launcher, I guess it doesn't re-write the changed file, anyone have any ideas?
*Edit*
I'm giving the Firmware Upgrade Tool a go. Fingers crossed.
*Edit edit*
Success! Probably should have done a bit more Googling before panicking. :slight_smile:
